Author Topic: Crank pulley - where to buy? - primeline parts?  (Read 3710 times)
JDX
  • Hersham, Surrey.
    • '02 2.2dti CDX estate.
« on: 15 August 2019, 11:45:04 »
So, finally managed to get the old crank pulley off my 2.2.dti....feeling pretty pleased with myself  :y
I now need help to buy a new one....I first tried local vauxhall dealer - I nearly fell over at how much they wanted...
ebay....found car spares direct who tell me their parts are supplied by Primeline in Germany but not necessarily made there!
I don't want to spend all day researching this so any help with suppliers? I would prefer a genuine part as I don't want it to break in 12 months time but I don't want to spend a fortune either. I saw an old post on here saying avoid a FEBI......I keep seeing TVD on some ebay listings, what does that mean?
Obvs I will replace the belt whilst everything is in bits but should I be replacing anything else whilst I'm at it? I plan on keeping the car for a while yet...owned her for 7 years & still enjoy driving her.
Thanks.
JDX
  • Hersham, Surrey.
Re: Crank pulley - where to buy? - primeline parts?
« Reply #1 on: 15 August 2019, 12:08:40 »
Torsion vibration damper...OK, worked that out  :o
Magwheels
    • 2.2 dti Elite saloon
« Reply #2 on: 15 August 2019, 22:31:02 »
Got mine from SC Motor factors in Tunbridge Wells but as its been on there for some time I can't remember the brand. About 70 quid I think.
Enceladus
  • London
« Reply #3 on: 16 August 2019, 10:42:02 »
Presumably the dealer gave you the GM part number. Might help if you posted that up.
« Reply #4 on: 16 August 2019, 14:53:09 »
My local VX parts dealer refused to supply the part numbers for various 'obselete' parts, preferi gg I stead to try to source alternatives and charging VX retail prices for.
Took some persuading that ifi had to buy pattern, the I would be doing so on my terms and not theirs and that with theepart number I could search globally for old stock because they clearly couldn't be bothered >:(
Enceladus
  • London
« Reply #5 on: 17 August 2019, 15:27:59 »
The pully would appear to be GM 55351711 (supersedes GM 9128177) . The bolt and the damper washer is GM 90502706. These parts are also used on Saabs.
Anyway a new pulley with bolt and washer is listed here @ £49.95 + £4 delivery.
Given that the bolt and washer is, on it's own, £21.50 delivered I don't imagine you'll do much better than that. This bolt and washer are said to be genuine GM.
« Last Edit: 17 August 2019, 15:39:01 by Enceladus »
JDX
  • Hersham, Surrey.
« Reply #6 on: 22 August 2019, 14:54:38 »
Thanks for all the replies.....I believe 55351711 IS the correct GM part no.... so I ended up buying an OEM part from a company called BGA. It was £57 & comes with a 5 year warranty. I intend using the old bolt with blue threadlock  :y
Page created in 0.029 seconds with 20 queries.
