Author Topic: Oil Leak front of car temp of engine?  (Read 8327 times)
Re: Oil Leak front of car temp of engine?
« Reply #15 on: 14 September 2019, 15:09:44 »
If leaking from the union to gearbox oil cooler, most likely the seal is fubar.  From memory, its a copper washer type, 2 per union.
« Reply #16 on: 14 September 2019, 15:23:22 »
Rubber o rings, similar to the aircon ones ;)
2011venator
  • WISBECH
    • Omega 2.2 CDX
« Reply #17 on: 14 September 2019, 21:00:38 »
it is missing one of the o rings ordered a couple today 94p each so not to bad  :)
« Reply #18 on: 14 September 2019, 21:07:36 »
Nice easy fix :y
Just top the cooler up with dexron 3 atf, fit the seals and bolt it back together :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19 on: 14 September 2019, 21:15:41 »
Nice easy fix :y
there's a helpful guide on checking and topping up ATF too  :)
2011venator
  • WISBECH
    • Omega 2.2 CDX
« Reply #20 on: 15 September 2019, 16:33:00 »
All sorted it was just the missing o-ring I presume this went missing when the new rad was fitted before I bought the car.
ordered a couple of 94p o rings from autovaux but as I was in town today I thought I would see if I could get some of the shelf mixed o-rings cheapest I could find was £8.00 which seems a waste as the rest will get chucked out after sitting in the garage for years Halfords however do a small pack of about 10 for £1 which were perfect.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #21 on: 15 September 2019, 16:42:34 »
don't forget to top up the fluid too  :y
2011venator
  • WISBECH
    • Omega 2.2 CDX
« Reply #22 on: 15 September 2019, 18:07:49 »
Yeah that is a job on the list
