Author Topic: Problem with pumps cable  (Read 4550 times)
jimjimanta
  • hellas
    • opel omega b , opel manta
« on: 14 September 2019, 18:21:40 »
I have a opel omega b 2.0L, 16V.
Pumps cable don't have power.
The check cable is Red-blue colour, and from the fusebox until pump, it looks like its cut.
Is something inserted in the cable line or is it continuous?
Re: Problem with pumps cable
« Reply #1 on: 14 September 2019, 18:28:03 »
Fuel pump?
jimjimanta
  • hellas
« Reply #2 on: 14 September 2019, 18:33:32 »
Yes fuel pump.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #3 on: 14 September 2019, 19:01:31 »
have you checked the fuel pump relay ?
jimjimanta
  • hellas
« Reply #4 on: 14 September 2019, 19:14:38 »
Yes and replaced with New relay.
I Checked the power and its ok.
But Checked the cable line with multimeter and so  its cut.
I don't know if the cable is cut, or if the are any fuse, or relay, or anythink inserted in the cable line.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 14 September 2019, 19:43:18 »
what model year and does it have air com ?
simtec 56.5 ecu (1996-1999) shows a fuse AFTER fuel pump relay
jimjimanta
  • hellas
« Reply #6 on: 14 September 2019, 19:54:55 »
Model is 1998 year.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #7 on: 14 September 2019, 20:00:43 »
according to Tolerance data
20 Amp fuse
middle row ,3rd from the right
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #8 on: 14 September 2019, 20:09:11 »
jimjimanta
  • hellas
« Reply #9 on: 15 September 2019, 08:22:04 »
Thank you very very  :y :y :y :y :y
 I looked at the fuses, near and I didn't think the fuse was inside.
I had stopped my mind.
Its all good now!!!
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #10 on: 15 September 2019, 10:19:20 »
Its all good now!!!
well done  :)
fuses blow for a reason (not always )
did you run low on fuel ? (pump is cooled/lubricated by fuel and pumps don't like running dry)
jimjimanta
  • hellas
« Reply #11 on: 15 September 2019, 11:57:18 »
The car he have lpg system.
The problem started when I changed pipes.
I didn't know that commercial pipes don't last a month ...
The pump go off , the tank filled the trash ..
