Author Topic: GM front pads. Asymetric backplates - which way round?  (Read 3572 times)
Enceladus
  • London
« on: 16 September 2019, 03:06:39 »
I want to fit a new set of GM front pads. Part# 9192124.
These pads have asymetric backplates. One of each pair has a glued on shim with a rectangular window cutout, So this pad is about 0.5mm thicker. The other pad in a pair has no shim. Please see photo.
I can't remember which pad goes under the piston. Is it the rectangular cutout?
upload
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: GM front pads. Asymetric backplates - which way round?
« Reply #1 on: 16 September 2019, 05:51:41 »
It's to stop the pad seizing to non piston side,as GM don't use copperslip, just slap copperslip everywhere, be fine then..
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #2 on: 16 September 2019, 22:51:40 »
That.
But thoroughly clean the caliper where the pad moves with brake cleaner, then scrape it before fitting the new pads.
