Proper Motor
Started by tunnie, 16 September 2019, 09:25:36
Not really going to waste more money on diagnostic stuff, cold start missfire and loss of coolant is enough for me. It's a case now of just keep topping it up until it lets go in a big way, or it's consumption gets to point it can't do a single run to or from work.
Running a proper car isn't really for you then... Better off buying a new Hyundai with its seven year warranty  :-X
Quote from: Doctor Gollum on 22 September 2019, 14:18:59
Yes he's not willing to sort out some minor issues on his V6 but tells us he wants a cheap V8!  ::)  ;D
It's OK just to sell the Omega because you want something different you know Tunnie!  :)
But you'd probably regret it after mind....  :-X
Quote from: Sir Tigger QC on 22 September 2019, 14:39:25
No time for DIY will very quickly equate to £1,000 bills every time it goes in. They won't tolerate neglect very long.
Minor issues, it's the head that's gone.  ;D
A clue in my lack of time was apparent when I took it to Serek for full service.
I can find some time for basic service work, like on the Zafira. But not constant almost nightly fiddling.
I want to save up for something new, just bad timing as my new car fund is depleted.
Quote from: tunnie on 22 September 2019, 16:22:19
Wow. Never seen that on *ANY* V6 Omega.  Not sure how you diagnosed that without removal. Impressive.
If coolant is getting in the cylinder, I would have thought it was far more likely to be the head gasket, rather than the head.
TBH, anything in your current price range suggested in recent threads will need some tinkering - generally the higher it depreciates, the more it will need. A much newer car can be better, but you will get hit on the depreciation yourself - whether you think that's more cost effective than paying someone to fix what is a fairly minor fault on the Omega (that you CBA to diy) depends on what you plan on buying.
I meant head gasket, just could not be bothered to type it.  ;D
You mention minor fault, but I've not a clue as to what you are referring to  :-\
It's quite possible it will be sent to the scrappy before end of the year....
Hmmm, if it did end up being scrapped.... what's the gearbox, diff and drivers door like on it?  :-\ ::) :)
Quote from: VXL V6 on 22 September 2019, 18:15:35
Gearbox in Serek's view was poor, to the point he wanted to replace it rather than change the fluid. It's better but still clonks into 3rd at times
Doors and body all excellent! Not sure on diff
Diff - as long as it's quiet at all speeds and isn't loosing fluid it's fine  ;D
It is a shame these cars are disappearing so rapidly now but it's to be expected, I just plan to keep two of mine going for as long as possible now, the third one, the daily might be replaced with something like a Volvo XC90 with a D5 if it expires in an expensive way.
Sounds like you need to pressurise the cooling system cold and see where it leaks.
I wouldn't be worrying about the head gasket until you've completely eliminated the radiator (passenger side tank seems to be most common area), radiator drain valve, HBV, water pump, oil cooler cover plate, heater matrix and all the rubber hoses for starters.
I also fail to see how you can have enough water leaking into a cylinder to get a misfire yet it's not immediately blowing the pressure cap under load. Sure you haven't got a leaky scuttle dripping water into the plug wells?
Quote from: Kevin Wood on 22 September 2019, 23:03:01
No it's not the scuttle, it miss fires after staying in a dry car park after the run to work. I've checked Coil pack areas, all dry. Plugs removed on 1-3-5. Plug 1 is very clean compared to rest ( see my other thread )
Serek pressure tested cooling system when he had it for a couple of weeks, he said it was fine with no leaks.  :-\
It was loosing coolant when I took it to him, with same misfire problem.
I agree on coolant loss to pressure, as on slow run to work it empties half it's headed tank, yet runs sweet as a nut and no excess pressure
Plug 5 was different to plugs 1+3...
And you didn't answer my question regarding bleeding it properly.
It will merrily boil off coolant until it runs out if there's an airlock in the heater ;D
dave the builder
was the water pump leaking when you took it to serek ? or the rad ? or what ?
back then you had a visible leak which I assume was resolved and the minor coolant loss is proving hard for you to find ?
