Pages: 1 [2] 3  All   Go Down
Author Topic: And again - I think I may have killed it this time..  (Read 15207 times)
Re: And again - I think I may have killed it this time..
« Reply #15 on: 17 September 2019, 00:25:31 »
90566605
Or
9117704
« Reply #16 on: 17 September 2019, 01:39:29 »
Right, the official repair panel is the inner wing assembly.
The part I mean for you to replace is a subassembly that forms part of the inner wing assembly.
Two minutes removing the boot side carpet and a torch will tell you infinitely more information than the EPC :y
And remember, you don't have to buy the repair panel. Nor do you have to use all of the panel if you do buy one.
The important part of the shock tower is the hole that mounts the shock - it needs to be the right size, at the right height, at the right angle, in the right place and strong enough. Cars are made from thin sheet metal, so strong enough is done by adding plenty of shape and a thick washer to reinforce the hole. Reverse engineering it from the other side isn't rocket science. But as already mentioned, it all takes time. And time is expensive, whether you're paying somebody else or using your own instead of doing something that you want to do.
That pretty much sums up how it is made but failure tends to be outside of the circumference of the actual mounting point, and consequently on a piece of single thickness steel curved in three directions.
If you remove the shock absorber and clean the area thoroughly, you will see exactly how it can fail... Basically the plug collar of the mounting Bush rubs away all the underseal, paint and primer and eventually rots it out un noticed...
Which is exactly what has happened here and in every previous case... Basically the panel wears and corrodes to the point where the weight of the car and fatigue stress it to breaking point ;)
« Reply #17 on: 17 September 2019, 04:10:46 »
Incidentally, this ONLY affects saloons.
Estates have a different shock arrangement whereby the top mount is away from the wheel arch and is far less pronce to collecting mud and salt etc ;)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #18 on: 17 September 2019, 08:39:36 »
This happened to two of my Omegas, most recent was OE03, an ex-police 3.2, in June of this year. I scrapped them both. I found extensive rust in the other rear turrets, and elsewhere. For many years I ran six Omegas, now I have one 20 year old estate.
terry paget
    • 3 Astras 2 Vectra
« Reply #19 on: 17 September 2019, 10:11:17 »
This is the RH turret of OE03, pre-MOT inspection June this year. Until I peeled back the carpet all seemed well. LH turret was OK, just a little rust. I spent £300 on the sills 2 years ago, bought a welder and  kept other Omegas going a bit longer. Some Omega owners plan to keep their cars going forever, not I. Nick has said Omegas were not designed to last forever, more recent cars are better.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #20 on: 17 September 2019, 10:40:26 »
Whaaaaat?????????
I have never said that, and never will. I think the Omega bodyshell is probably one of the better examples of a late seventies design, and resists rust better than many of its shorter lived contemporaries: look at Granadas(mk2 or 3, doesn't matter), 5 series BMWs, CX, Renault 20(remember those ;D )etc. Even E-class Mercs aren't immune; once rust takes hold it rapidly munches its way through the car.
More recent cars are not better, they're going backwards as the high cost of routine maintenance and repair costs devalue them quicker than ever. And then there are the flaws that come to light after a few years, we've had the the discussion about TDCI Mondeos several times.
Old cars wore out quickly and rusted away at a similar rate, hence the fixation on 'low mileage'. Engine management improved the service life of engines, and better rust proofing had a similar effect on the bodies. Now, we have complicated interlinked systems that cost a fortune to repair, and the bodies aren't much better. I read recently that cars are designed for a 7 year service-life. I wish I could remember where. It certainly shows in what's on the road - the number of 10 year old mid to large size cars seems to be decreasing. Patched up 20 year old cars used to be common, but aren't any more - when did you last see an early Vectra, Mondeo or P406?
terry paget
    • 3 Astras 2 Vectra
« Reply #21 on: 17 September 2019, 11:29:36 »
I beg pardon, Nick. I got that wrong.
I agree that 7 years seems to be the design life of modern cars. My local Vauxhall dealer only stocks used Vauxhalls less than 5 years old, and asks hot prices for them, nothing under £9000, and all very low mileage.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #22 on: 17 September 2019, 11:53:16 »
100% agree
but do see a few vectra B's around here, but probably because I live in a place where old people garage their cars still and because I'm a bit of a 90s vauxhall fan ,so notice them, even see cavs ,but not often  :(
As for cutting a turret from a 16+ year old car ,I think you's be better finding a brand new available repair panel from another make or model and cutting welding to fit ,or use fresh new metal and completely re-fabricate the top , as Nick has said before, it's hidden anyway,so just needs to be strong.
a section from an old omega/catrera  may not look rusty but after 16+ years of pot-holes and speed bumps the metal must be fatigued /case hardened weakened I'd have thought  :-\
  • Chatham, Kent
« Reply #23 on: 17 September 2019, 12:12:45 »
As for cutting a turret from a 16+ year old car ,I think you'd be better finding a brand new available repair panel from another make or model and cutting welding to fit ,or use fresh new metal and completely re-fabricate the top , as Nick has said before, it's hidden anyway,so just needs to be strong.
Cutting a panel from another car has other costs, you've got to: find one; cut a bigger section than you'll need and you're unlikely to be doing it in your nice warm, fully equipped workshop with a nubile helper providing limitless coffee; do the same fitting and adjusting that making a new panel requires; unless you pick all of the joints apart and reweld them, you're never going to be sure how much better it actually is. This all takes a lot of time, and that's expensive.
Adapting another similar repair panel is a good idea; something like a Corsa front strut tower ought to be cheap and strong enough.
Looking at Terry's pic it's not that complicated a panel, so making a replacement to weld in from £5's worth of sheet steel isn't any more actual work. Shape it around the gas bottle/lamp-post, make the top flat to save time, but double up the thickness, add a thick washer for the shock bolt, and fold the flanges with some wide pliers(glaziers pliers are cheap - mine are Eclipse and cost £5 at a show). Underseal the outside, the inside will be covered by the carpet and all the junk in the boot.
« Reply #24 on: 17 September 2019, 12:34:28 »
A new repair panel consists of the entire inner wing, from the tail light housing to the C pillar. If you can find one. And necessitates removing the rear quarter/bumper/interior/sill/bootlid/rear screen etc.
The required piece from another car (or from a repair panel) is the only effective repair, as it only requires stripping the boot... but I concede the point regarding a potential repeat by using a used one, although they are easy enough to check prior to cutting out. ;)
Using one from a similar design might work, but the shock absorber geometry is important and it's a lot of work on a whim.
Omega A/Senator B may be an appropriate panel, again if you can get one, or possibly the Holden Commodore VW/X/Y/Z:-\
Andy Clears (andyc) may be able to better advise as chassis up restorations of Vx barges is his thing :y
terry paget
    • 3 Astras 2 Vectra
« Reply #25 on: 17 September 2019, 15:43:59 »
Above is the nearside turret of OE03, the side that failed on my earlier Omega. Not my world, but is that one steel pressing that is spot welded into the rear wing?
  • Chatham, Kent
« Reply #26 on: 17 September 2019, 15:55:00 »
That's how it's done, the circles around the pressing are the spot welds. And if you look around the top, you can see where the reinforcing cup for the shock is welded on. I suspect the rusty mark is its bottom edge.
terry paget
    • 3 Astras 2 Vectra
« Reply #27 on: 17 September 2019, 16:08:17 »
Forgive my innocence, but if the turret pressing was available as a spare part, could not the spot welds be drilled out, allowing a new turret to be welded in?
  • Chatham, Kent
« Reply #28 on: 17 September 2019, 16:19:36 »
Yes. But you would have to allow for the remaining panel to have been thinned by rust.
Remember, rust is ALWAYS worse than it looked when you started the job
« Reply #29 on: 17 September 2019, 16:59:31 »
This is exactly what I suggested both times yours failed and for this case :y
Pages: 1 [2] 3  All   Go Up
