Author Topic: Headlamps help  (Read 2570 times)
Stevelaw67
  • Derby
    • Vauxhall Omega
Headlamps help
« on: 21 September 2019, 14:00:32 »
Looking for both uk headlamps for my omega B 2002 part No’s R/H 9193420 & L/H 9193419 need clear lenses for mot
Re: Headlamps help
« Reply #1 on: 21 September 2019, 14:12:50 »
You can refurbish the headlight lenses easily enough with very fine wet and dry and G3 rubbing compound.
Requires about 15 minutes elbow grease each side :y
Obviously mask the surrounding body work when  you use the wet and dry  ;)
« Last Edit: 21 September 2019, 14:16:01 by Doctor Gollum »
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Re: Headlamps help
« Reply #2 on: 21 September 2019, 14:29:32 »
Yep, done this a couple of times on my dads FL Desmond.  Can also pop the light off as well - Relatively easy if i recall.
Re: Headlamps help
« Reply #3 on: 21 September 2019, 14:53:29 »
Or if you are work shy, use the £18 3M headlight restorer kit that fits in a drill.  I spend about 20mins a side, and it does a better job that spending the same amount of time doing it by hand.
I did my Omega's ones again for the MOT, its surprising how you don't notice that they have gone a bit cloudy until you refurb one of them ;D
kevinp58
  • kent
    • 2002 3.2 elite
Re: Headlamps help
« Reply #4 on: 22 September 2019, 17:05:23 »
Yup the Scotch 3M kit works very well I did mine and they came up like brand new
