Jaguar XF
Started by tunnie, 21 September 2019, 14:05:10
Raeturbo
Motorway driving the car will be in Eighth gear (if you have one :y ;D)
Laying a rubber road.
Quote from: Raeturbo on 24 September 2019, 19:14:13
Only when I'm in works time ;).
I'll look up the ratios (or try mine - though mine likely has a different diff?).  Though using the FC, there is little difference in MPG when cruising between any gear that's high enough not to spool the 2nd turbo.
Raeturbo
Yes could be a different final drive ratio too perhaps
Raeturbo
Quote from: TheBoy on 24 September 2019, 19:18:11
Yes we don't want the small turbo working too :y
