Author Topic: Brakes crap again  (Read 3661 times)
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
Brakes crap again
« on: 26 September 2019, 08:07:25 »
Hi
So a couple of months ago I changed the fluid, replaced back discs pads, gave the rear pistons a freeing off, not that they were seized per say, mainly gave them a bit of movement to keep them free moving - the old inny outy!. I also found the slider on F/N/S caliper a bit stuck so freed that off and checked other side, which was ok. After this the brakes had a nice sharp bite to them, for a couple of weeks, then one day it went back to how they were before i.e pedal goes quite far down before bite and more of a shove to stop.
I have noticed on very rare occasion they are back to being good i.e. firm pedal. Could it be air still in the system. I used a ezi-bleed to change fluid.
Cheers
Andrew
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
Re: Brakes crap again
« Reply #1 on: 26 September 2019, 09:21:06 »
I would start with bleeding them again.
Jan Suhr
Stockholm, Sweden
www.protouring.se
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #2 on: 26 September 2019, 09:49:03 »
I observe that the older the car, the more likely is this phenomenon. I suspect master cylinder wear.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 26 September 2019, 12:57:55 »
exactly.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #4 on: 26 September 2019, 13:33:40 »
When you freed off the sliding calipers, were the boots intact and did you lubricate the sliders - if so what did you use? A firmer than normal pedal could be related to the sliding caliper sticking again. Worth checking first before bleeding or dismantling the master cylinder.
grifter
  • Paisley, Scotland
« Reply #5 on: 26 September 2019, 17:21:44 »
Quite sure the boot was intact, I think it had just fallen off it's lip somehow, just the top one. I used some standard grease to lube them up. I'll give it a double check tomorrow.
johnnydog
  • Lancashire
« Reply #6 on: 27 September 2019, 10:13:23 »
Don't use copper slip on them  it is an antiseize rather than a lubricant.
Ideally, you need a heat resistant lubricant for the sliders due to the heat that can be generated ftom the brakes. I personally apply a very light smear of a CV joint grease on the slider pins before reassembly - works perfectly for me when overhauling this type of caliper.
grifter
  • Paisley, Scotland
« Reply #7 on: 28 September 2019, 15:36:51 »
Wouldn't ever use copperslip on moving part. If I've not got CV grease to hand just use normal grease.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #8 on: 28 September 2019, 21:11:36 »
exactly.
2nd the above....
Also in the older days we use to have a stuff called Hmp grease.
Hoof'land storeman.
