Author Topic: Service kit for 2.5 petrol Omega  (Read 8580 times)
vegasgogo
  • Essex
    • Omega
« on: 26 September 2019, 17:31:04 »
Sorry this is a very basic question, am getting a service on my W-reg 2000 2.5l Elite auto and there's two options to buy the kit - one with 4 plugs and a metal oil filter, the other has 6 plugs with a paper filter. Which one would I go for? Thanks in advance.
Re: Service kit for 2.5 petrol Omega
« Reply #1 on: 26 September 2019, 17:33:09 »
I'd buy the bits you *need* individually.
vegasgogo
  • Essex
    • Omega
« Reply #2 on: 26 September 2019, 17:34:42 »
If I knew what they were I wouldn't need to ask.
« Reply #3 on: 26 September 2019, 17:50:12 »
Being the 2.5...
You *need* 6 plugs... Which hopefully answers your question.
If we presume that it's post '98 then the paper filter is the one you also *need* ;)
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« Reply #4 on: 26 September 2019, 17:53:41 »
Will need 6 spark plugs. To find out what type oil filter you need, look under the passenger side towards the front of the engine. You will see either a normal oil filter, if not a normal filter then it is a paper element type.
As Doctor Gollum said.
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
« Reply #5 on: 26 September 2019, 17:57:09 »
Should be a paper filter ;)
If only because I only ever had the proper v6 :D
vegasgogo
  • Essex
    • Omega
« Reply #6 on: 26 September 2019, 17:58:58 »
Thank you guys :-) Will be its first service in years.
« Reply #7 on: 26 September 2019, 18:20:52 »
Word of advice, remove a plug lead and replace that plug, refit plug lead.
Repeat 6 times ;)
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #8 on: 26 September 2019, 19:27:19 »
Repeat 6 times ;)
Can you number the leads first? :-[  just asking. :-\
« Reply #9 on: 26 September 2019, 19:35:04 »
Repeat 6 times ;)
You could, but easier just to do one at a time  ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #10 on: 26 September 2019, 19:47:58 »
Repeat 6 times ;)
You can, buy some small white cable ties, and attach the required amount to each lead. Or use some tip-ex and put a dot on each lead.
If it hasn't been serviced for a good few years, will also need anti- freeze change, brake fluid change, check diff and gbox levels,  fuel filter, pollen filter, air filter, ,, if it has spark plug leads a new set of them.
Hoof'land storeman.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #11 on: 26 September 2019, 21:22:12 »
And make sure you clean the breathers.
vegasgogo
  • Essex
    • Omega
« Reply #12 on: 26 September 2019, 21:49:24 »
Thanks again
Keith ABS
  • Maldon Essex
« Reply #13 on: 27 September 2019, 09:50:39 »
 Let me know if you need HT leads :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #14 on: 27 September 2019, 12:21:02 »
Repeat 6 times ;)
finally, some complete advice.
