Author Topic: Fuel Tank Rust  (Read 3299 times)
TestOmega
  • Mississauga, Canada
  • Been helped, will help.
Fuel Tank Rust
« on: 07 October 2019, 08:43:30 »
I have the Omega X30XE Saloon equivalent (Cadillac Catera 2001). I noticed quite a bit of rust on the underbody of the fuel/petrol tank. Are these tank internally plastic shell or it is all metal? Could it rust through and start leaking? I am not a mechanic and at times am quite novice on these issues.
Regards.
!!!!!!!!!!!!!!!!!!  May I be blessed to give more than I receive  !!!!!!!!!!!!!!!!!!
    • 530D M Sport, 330i Coupe
Re: Fuel Tank Rust
« Reply #1 on: 07 October 2019, 09:02:56 »
Tanks are plastic, tank straps corrode though!
TestOmega
Re: Fuel Tank Rust
« Reply #2 on: 07 October 2019, 09:05:13 »
Thank you for the fast answer. I am at peace.
I will look into the straps and other items and inspect.
Regards.
Re: Fuel Tank Rust
« Reply #3 on: 10 October 2019, 17:38:57 »
UK ones are plastic, as said. Irmscher kitted cars have a metal cover to protect the tank. Not sure what is fitted to US cars.
Re: Fuel Tank Rust
« Reply #4 on: 10 October 2019, 19:44:52 »
You mean the heat shield which sits between the tank and cross pipe from back box to right hand exit on the split tailpipe option ;)
Re: Fuel Tank Rust
« Reply #5 on: 11 October 2019, 09:01:24 »
Indeed. And these can show signs of corrosion.  It pretty much covers the whole base of the tank on mine. Or at least it would if I ever bothered fitting it ;D
Re: Fuel Tank Rust
« Reply #6 on: 11 October 2019, 14:35:18 »
The estate version is only about 8" deep, but the tank on the saloon is a different shape and probably sits a bit further aft, so warrants the extra ;)
Re: Fuel Tank Rust
« Reply #7 on: 11 October 2019, 17:12:50 »
Neither the saloon or estate warrant it.
