Author Topic: Bad idling in the morning  (Read 7360 times)
Gintonic
  • Macedonia
    • Omega B FL, 3.0 manual
Re: Bad idling in the morning
« Reply #15 on: 20 October 2019, 20:33:31 »
Ok sorry , did not understand you .And where  is the input for it? Is it easy to check or i have to take ot the wipers and plastic underneath?
« Reply #16 on: 21 October 2019, 00:40:45 »
It lives on the back of the 135 head and easily found by following the pipe from the right hand inner wing. You're looking for this...https://www.ebay.co.uk/itm/Vauxhall-Opel-Omega-B-2-2-Petrol-Engine-Vacuum-Purge-Valve-Solenoid-0280142361/302344895286?hash=item466528fb36:g:h-8AAOSw3YJZOqff
If your car is left hand drive, you might find access easier with the scuttle removed, but wiper motor should be out of the way... also removing the plenum will give better access as well.
Test is as described here... https://youtu.be/5yaTOBQZFuw
Hth :y
« Last Edit: 21 October 2019, 00:55:56 by Doctor Gollum »
« Reply #17 on: 21 October 2019, 04:17:18 »
You could always use an old plug and length of loom to make it easier...
