Author Topic: crank sensor  (Read 9360 times)
kevinp58
  • kent
    • 2002 3.2 elite
crank sensor
« on: 11 October 2019, 14:10:03 »
Hi where is best place to get a 3.2 crank sensor please also a knock sensor
Re: crank sensor
« Reply #1 on: 11 October 2019, 14:33:03 »
The nearest genuine Vauxhall dealer that you can genuinely walk into :y
Next...
kevinp58
  • kent
    • 2002 3.2 elite
Re: crank sensor
« Reply #2 on: 11 October 2019, 15:07:50 »
Next...
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: crank sensor
« Reply #3 on: 11 October 2019, 16:28:31 »
How about this....
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F223534673818
I have bought from this seller before and his items were 100%.
Re: crank sensor
« Reply #4 on: 11 October 2019, 17:14:27 »
Risky buying from anywhere other than a real brick and mortar GM dealer for this item.
Re: crank sensor
« Reply #5 on: 11 October 2019, 17:14:59 »
Knock sensors can normally be repaired, if its the wiring that's mangled (most likely)
kevinp58
  • kent
    • 2002 3.2 elite
Re: crank sensor
« Reply #6 on: 11 October 2019, 17:57:32 »
kevinp58
  • kent
    • 2002 3.2 elite
Re: crank sensor
« Reply #7 on: 11 October 2019, 17:59:14 »
Got to check it out yet but the car just stopped then after a while started up fine so classic signs really  :y
Re: crank sensor
« Reply #8 on: 11 October 2019, 18:16:18 »
Classic crank sensor - but do the pedal trick first.
Why do you think knock sensor is toast?
kevinp58
  • kent
    • 2002 3.2 elite
Re: crank sensor
« Reply #9 on: 11 October 2019, 20:54:55 »
 I did the test and it showed a 0330
Re: crank sensor
« Reply #10 on: 12 October 2019, 09:44:07 »
Before condemming it, does the car noticibly hold back under load at around 2000rpm?
kevinp58
  • kent
    • 2002 3.2 elite
Re: crank sensor
« Reply #11 on: 12 October 2019, 14:19:44 »
 No not really if I give it some the kickdown works
Re: crank sensor
« Reply #12 on: 12 October 2019, 16:07:50 »
I'd suggest the knocksensor code is false then :)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: crank sensor
« Reply #13 on: 12 October 2019, 16:29:29 »
How about this....
Just buy it, my last one in the same packaging as that from a dealer £75.00
Hoof'land storeman.
Enceladus
  • London
Re: crank sensor
« Reply #14 on: 12 October 2019, 19:07:15 »
I agree. They are 7-10 days special order from Germany. No tradeclub or trade discount any more. And all assuming you can find a dealer willing to 'special' order. And you'll have to prepay up front. Somebody reported on here a couple of weeks circa £100.
