Author Topic: Astra H plugs  (Read 11140 times)
Re: Astra H plugs
« Reply #15 on: 16 October 2019, 19:50:11 »
If they're too long you run the risk of being struck by the piston, and too short and they become shielded by the head and the mixture won't burn cleanly.
Like you said, even genuine plugs are less than a tenner, so really not worth the risk :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Astra H plugs
« Reply #16 on: 17 October 2019, 10:33:11 »
Ditching distributors and points based ignition arrangements for high ouput mapped systems is the root of longer plug life. FI further improved it.
100k intervals don't appeal to me though.
Enceladus
  • London
Re: Astra H plugs
« Reply #17 on: 17 October 2019, 12:31:14 »
I've put Omega plugs in all sorts of cars without issue  :y if they fit they've always worked
Interesting. I was taught that plugs with too hot a heat rating would oil up when idling, while cool plugs would glow red hot at full power and cause pre-ignition. I suspect most modern petrol Vauxhalls have similar requirements, so the plugs are interchangeable. Having said that, plugs are so cheap it's probably not worth the risk.
Omega plugs are the same heat range as those in your Astra.
Bosch & Beru, NGK, Champion etc use different scales for heat.
Most of the Omega plugs were Bosch and 8 on the Bosch heatscale. Approximately equivalent to 5 on the NGK scale. NGK 6 would be approximately equivalent to 7 on the Bosch scale.
I don't believe your NGK plugs are the "100K miles" version. They're standard model Copper/Nickel plugs. The extreme long life plugs will be the multi-pole Beru Platinum/Iridium plugs Z190.
That said if your NGK plugs have truly lasted 103K miles, then I would replace with the same.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Astra H plugs
« Reply #18 on: 17 October 2019, 14:12:20 »
Every motor I've ever owned, had new plugs every service,.
Hoof'land storeman.
Re: Astra H plugs
« Reply #19 on: 17 October 2019, 15:19:14 »
Spark plugs, eh? Complicated stuff.
  • Chatham, Kent
Re: Astra H plugs
« Reply #20 on: 17 October 2019, 16:59:34 »
exactly
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Astra H plugs
« Reply #21 on: 17 October 2019, 22:51:54 »
Thanks for that. May I take it that the 5 in the NGK label NGK R ZFR5F was the heat rating? I note Haynes prescribes Champion RC 10MCC R6 plugs for the Astra 1.4 and 1.6 normally aspirated, NGK IFR7X-7G for the 1.4 turbo, and NGK ZFR6BP-G for the 1.6 turbo, very specific.
The plugs I removed were well eroded, and I imagine were original. As said before, modern cars are wonderful. The Senator was not so good, electronic ignition, but with a distributor at the front behind the open cheese grater grill, which allowed the rain to blow in.
Enceladus
  • London
Re: Astra H plugs
« Reply #22 on: 18 October 2019, 03:10:18 »
That's right the '5' on the NGK is the heat rating.
As I see it the Vauxhall EPC lists two possible factory fit plugs for your 1.6. Bosch FQR8LE2 and Champion RC10MCC (aka OE198/T10). These and your NGK ZFR5F are all equivalents and are single pole Copper/Nickel. However they all use different heat scales and counter intuitively a lower number is hotter on the NGK scale. Hence Bosch 8 <=> Champion 10 <=> NGK 5. It's never a precise equivalence.
The turbo plugs are colder and are Iridium and Platinum.
So likely somebody changed the plugs in your Astra for the NGKs some time ago. Seems probable they were not factory fit but aftermarket.
I wish I still had my Senator.
terry paget
    • 3 Astras 2 Vectra
Re: Astra H plugs
« Reply #23 on: 19 October 2019, 21:16:18 »
Like most of the use cars, I buy this car came without any service history. Having done over 100,000 miles I thought it prudent to change the plugs. And as the gaps were just about 1mm I reckonned they had done some miles.
On my Senators I changed the plugs every 10000 miles, but they still would not start on wet mornings if left outside. I used to keep spare distributor caps with numbered leads standing by. In this respect Omegas are much better, as are the fwd Astras, Vectras, etc.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Astra H plugs
« Reply #24 on: 20 October 2019, 09:01:36 »
How strange,out he Senators and the Monza[all 12v engines]I never had any problems starting them no matter what the weather or how long they'd been stood for[as long as the battery had enough charge]the Omega is no better/worse in this regard.Never owned an Astra or Vectra so can't comment on those.
Re: Astra H plugs
« Reply #25 on: 20 October 2019, 09:11:42 »
How strange,out he Senators and the Monza[all 12v engines]I never had any problems starting them no matter what the weather or how long they'd been stood for[as long as the battery had enough charge]the Omega is no better/worse in this regard. ....
The only time my 24v Senator could be iffy was if you started it, moved it & switched off while still 'on choke'  ..... but that is apparently a common call out for recovery companies.
BazaJT
Re: Astra H plugs
« Reply #26 on: 20 October 2019, 09:14:12 »
Yes my XJ6 was like that-as I believe all the XJ's were.
Re: Astra H plugs
« Reply #27 on: 20 October 2019, 09:46:48 »
That's probably more the move to more integrated engine management and the demise of distributors, rather than anything to do with the plugs.
  • Chatham, Kent
Re: Astra H plugs
« Reply #28 on: 20 October 2019, 12:36:45 »
high quality rotor arms and distributor caps made a big difference. They are some of the few parts I do insist on branded products; I won't buy Intermotor ignition parts as I've had lots of failures. Lucas, Motorcraft or Bosch were what I bought, with NGK plugs
