Author Topic: Heatshield studs  (Read 6084 times)
razzo
  • Crapital
    • 97 3.0 Elite
Heatshield studs
« on: 28 October 2019, 17:20:28 »
Noticed some of the studs that secure the heat shields under the car near the back boxes have broken off and wondered if anyone has any idea of a repair
Ta  :(
Re: Heatshield studs
« Reply #1 on: 28 October 2019, 18:03:51 »
Either drill through or cut the head off a suitable self tapping bolt and weld it...
Option three is ignore it.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 28 October 2019, 18:07:55 »
Drill straight thro, put a river in. Stays put, forever.
Hoof'land storeman.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #3 on: 28 October 2019, 22:44:52 »
Did a mod a while ago when my car was still SORNed, in a nutshell I drilled out the original threads and put stainless steel machine screws, grip washers and nuts on. Seems overkill but I didnt want to start drilling holes in my floorpan to then to stick mil steel stuff in there that would just make a dozen areas prone to rust.
On the odd occasion I've needed to remove a heatshield the stainless fittings make it a breeze vs rusty old nuts.  :y
Like anything depends how far you want to go.
    • 530D M Sport, 330i Coupe
« Reply #4 on: 29 October 2019, 08:00:33 »
The bodge I've seen done on a car where the heatshield mounts have rusted through is 'No More Nails'.....  ;D
« Reply #5 on: 29 October 2019, 08:45:22 »
...... but suffers a tad from damp .....     :)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #6 on: 29 October 2019, 11:18:54 »
you can buy the original type of spot welded copper studs too. They're only a few pence each, which makes £800 for the welder slightly more affordable :) . Fortunately, I bought mine when they were a LOT cheaper.
Fitting the heat shields to the bin is the easiest fix.
« Reply #7 on: 29 October 2019, 19:01:33 »
My MV6 ran for over a dozen years without any of the heatshields on, due to no studs.
I wouldn't concern yourself too much ;)
« Reply #8 on: 29 October 2019, 23:30:43 »
Yep, my solution was also to re-install the heatshields..... in my garage loft. They might still be there. ;D
« Reply #9 on: 30 October 2019, 17:37:53 »
Now you mention it, mine might have been there until about 6yr4m ago....
« Reply #10 on: 30 October 2019, 19:07:43 »
Blimey, was that that long ago :o
« Reply #11 on: 30 October 2019, 20:36:12 »
I remember it well, as I broke my nose and ribs a few days earlier, and had to leave a (wo)man down coming back from hols just before.
July 2013 was an utter shit month.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #12 on: 30 October 2019, 21:21:52 »
Literally last week I saw the best / funniest heat shield repair ever.
On a focus I think. They’re super common for the heat shielding to rot away around the stud and nut. Normal fix is big washer. However somebody (hopefully not a garage!) had simply removed the nut and twisted on to the stud a plastic bottle top from an oasis or similar 🤣🤣🤣 thought that was pretty cool. It got noted on the invoice 😂😂😂
RIP Paul Lovejoy
