Author Topic: 1998 2,0 auto fault codes. Non starter.  (Read 7739 times)
Dave Ghost
  • North East
    • 1998 2.0 Vauxhall Omega
« on: 04 November 2019, 14:08:41 »
I was recently at MOT with my car ( passed no advisories ) drove back home no problems. Went to work the next day and the car just cut out. ( No lights came on. ) the cars started up again but only ran for about 20 seconds then just cut out again.
I did the paperclip test and got two codes.
0335  Incorrect rpm signal
0340 Camshaft sensor incorrect signal
I have changed the Cam sensor with an original part from Autovaux. but the car still wont start.
It sometimes sounds like it is firing but does not start.
What is the " Incorrect rpm signal " and how do I sort it.
any help would be greatly appreciated.
  • Online Online
Re: 1998 2,0 auto fault codes. Non starter.
« Reply #1 on: 04 November 2019, 14:11:57 »
I think I'm right in saying that the 0335 is because the engine isn't running.
Mmm? I don't believe Autovaux don't always send OE parts  :-\
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #2 on: 04 November 2019, 14:26:16 »
Maybe it should go back to the garage that did the MOT if the car was ok prior to this.
Dave Ghost
  • North East
« Reply #3 on: 04 November 2019, 14:29:42 »
I was with the car the whole time for MOT They didn't touch the engine. I've always been there with my cars and trust them.
Dave Ghost
  • North East
« Reply #4 on: 04 November 2019, 14:32:30 »
I was also thinking that i would get a code that states the engine is not running but was not sure.
The part was a Siemens part and looks identical to the original from part number and everything.
« Reply #5 on: 04 November 2019, 19:28:18 »
0335 is crank sensor
0340 is cam sensor
I *think* the 2.0l can "run" with only one of them working, but might be a bugger to start.
« Reply #6 on: 04 November 2019, 19:38:36 »
You're thinking of the early V6 ;)
  • Online Online
« Reply #7 on: 04 November 2019, 19:47:48 »
Am I?  :-\
I often have no idea what I'm thinking or doing these days  ::) ::)
Dave Ghost
  • North East
« Reply #8 on: 04 November 2019, 20:49:53 »
0340 is cam sensor
according to the fault code list for the 2.0 0335 is incorrect rpm signal.  it is however for the 2.2 a crank sensor.
« Reply #9 on: 04 November 2019, 21:08:11 »
Fuel? How much in the tank? Does the pump prime when you turn the ignition on?
Dave Ghost
  • North East
« Reply #10 on: 05 November 2019, 10:32:03 »
Tank is half full.  Going to have a look at the pump and relays next. ( when the weather allows me to. )
Enceladus
  • London
« Reply #11 on: 05 November 2019, 10:40:31 »
0340 is cam sensor
The RPM is calculated from the signal provided by the crank sensor. So both lists are correct.
P0335 is a standard OBDii code for a problem with the crankshaft speed sensor.
P0340 is a standard OBDii code for a problem with the camshaft speed sensor.
I suspect that the engine needs to crank for more than a pre-defined period, without starting, before the ECU will try to operate with no cam signal. (Or vice-versa on some non V6 engines). Try cranking for at least 10 seconds. If no start then try at least 20 seconds.
It looks like both the crank and cam sensors connect directly to the Simtec ECU. So if your sensors are good then the fault must be in the loom feeding the sensors. Most likely the mating halves of the connectors on the sensors.
I find it hard to believe that both sensors failed at the same time. So I'm also wondering under what circumstances a failed crank sensor could induce a false positive in the cam sensor.
Dave Ghost
  • North East
« Reply #12 on: 18 November 2019, 12:47:39 »
0340 is cam sensor
Ive changed both of the sensors for original parts cheaked the timing and it is spot on.  still no joy. ( No lights on )
I had the car in a garage to get repaired. they did get it running. However. The heater bypass solenoid ( vacume switch ) that is broken. they just unplugged that and it started. the car ran for 3 days. I went to work on saterday and had to walk back home. I just dont understand how a part for the heater will stop the car from running. there are two vacume pipes, one goes to the heater bypass valve and the other looks like it goes into the bulkhead. the electric cable is a two pin cable.
 my guess is that it is something really stupid like a relay or the fuel cutoff switch if it has one.
Dave Ghost
  • North East
« Reply #13 on: 18 November 2019, 13:28:03 »
I have finally found the name for that bloody broken part. It is called the " Intake duct switch over valve solenoid valve "
Enceladus
  • London
« Reply #14 on: 18 November 2019, 15:05:29 »
Is it not the secondary air valve, GM part nr 90466214?
In which case it's allowing air from the secondary air pump into the exhaust manifold following a cold start. To help burn rich fuel until the exhaust heats up.
I don't know exactly how these work on the X20XEV, but on a V6, some folks disable the secondary air pump and just do without it, more trouble than it's worth. Doing so might make HC too high for a minute or two whilst the exhaust heats.
Disconnecting the valve might cure the fault. But might also introduce a fault code.
Might be useful to check for a split hose between the pump and the valve.
« Last Edit: 18 November 2019, 15:12:17 by Enceladus »
