Author Topic: Brake bleed - ABS  (Read 3252 times)
cwill144
  • Oxford
    • 1998 MV6
Brake bleed - ABS
« on: 11 November 2019, 09:05:55 »
I have just changed most of the brake pipes on my MV6 3.0L. and now need to bleed the system. when I look in the Manual it list the 3 & 4 Channel ABS bleeding sequence which are different. My car is a 98 which is when they changed, it has TC and has 4 pipes coming out of the Bosch unit but how can I tell if it is a 3 or 4 channel unit? and any tips on bleeding the system?
Re: Brake bleed - ABS
« Reply #1 on: 11 November 2019, 09:13:09 »
4 channel.
Start with rear, then front, and clutch if the reservoir was drained.  :y
cwill144
  • Oxford
    • 1998 MV6
« Reply #2 on: 11 November 2019, 13:11:32 »
As mine has 4 pipes, is it the 4 channel unit?
« Reply #3 on: 11 November 2019, 13:20:13 »
if you have TC, then it's 4 channel  :y
 (as opposed to the 3 channel that looks at both rear wheels as one  :))
« Reply #4 on: 12 November 2019, 18:29:44 »
TC was available on 3 and 4 channel.
If the last LETTER of you VIN is W, its 4 channel, if its V, its 3 channel.
« Reply #5 on: 12 November 2019, 20:53:18 »
I stand corrected .....  :-[
« Reply #6 on: 13 November 2019, 17:11:20 »
Said the man in orthopaedic shoes.
« Reply #7 on: 13 November 2019, 17:23:20 »
 ;D ;D
