Author Topic: Autobox Thrust Washer- LOADS of Fear Project  (Read 2591 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 27 August 2008, 18:58:26 »
Thought I would give an update on changing the broken thrust washer on my 2.5 V6 auto.
The removal of the gearbox was a fairly straighforward if messy process.  Oil lost out of the cooler pipes till you "swap" the ends over and out of the torque convertor which came loose.
It most definitely helps if there are two people. I am very,very grateful to Omegatoy for his assistance and support. There seems to be endless wires and tubes attached to the gearbox which need detaching or unclipping. For example the breather tube is located at the rear of the box on top and is very hard to get at.
After a good clean up of the exterior it was into the workshop and off with the two pans to empty them of any dirt or bits. Omegatoy thought the oil was a little black. Ever the optimist I thought it was pinkish!
Next the bell housing end of the box was dismantled(once it was securely held upright) using Sassanach's excellent how to in the maintenance guides. The faces of the components are damaged where the long since removed broken thrust washer should be. Worse the oil, although only changed relatively recently (mileage wise), is a dark pinkish colour.
I do however have the necessary parts to reassemble the gearbox tomorrow thankfully. At this stage the pessimist in me says even if I ever get it all back together it will be too far gone to work properly. The optimist in me says sure it will be fine. Time for another beer!
Plan B is to obtain a S/H AR35 and get it over here and fit it...... First lets see how Plan A goes. All for now more beer beckons.......... ;D ;D
Can you believe that such a small part can cause such a lot of trouble?
The Sonnax thrust washer part no is 54701-03K and the large rubber washer is GM part number 96017189. You can get the washer washer from JPAT.
varche
Re: Autobox Thrust Washer- LOADS of Fear Project
« Reply #1 on: 27 August 2008, 19:06:42 »
Good progess.
Watch that Omegatoy mind, he has a habit of:
a) wrecking your expensive sockets
b) wrecking your house, using things he finds to modify into some tool
;D
Omegatoy
  • UK
« Reply #2 on: 27 August 2008, 21:34:45 »
Good progess.
;D
Expensive?????????????? that was the cheapest chinese copy of a socket it possible to buy!!!!!
But tools are useful, and anyway i returned it to its original state when it had done the job!!
Have to say once i found Varche,s place(even further out in the sticks than i am) it was a pleasure to work with him !! however once again was unimpressed with the room to work around a v6!! fancy having to take the cats off to remove a gearbox!! on the td you dont touch the exhaust for a gearbox prob!!! secondly had it been a manual we could have slipped a new clutch in and bolted it all back together today!!
sludgepumps/PAH!!!!! ;D
« Last Edit: 27 August 2008, 21:35:26 by Omegatoy »
« Reply #3 on: 27 August 2008, 21:43:06 »
Yeah, downpipes have to come off a v6 to do gearbox...
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #4 on: 27 August 2008, 21:45:52 »
Good progess.
;D
ahh yes, garage door opener = timing chain tensioner tool  :y
Omegatoy
  • UK
« Reply #5 on: 27 August 2008, 21:46:39 »
damn silly idea!!!!  >:( but i suppose vxhall could then say sorry sir your exhaust is beyond repair so we fitted a new one thats hundreds more punds on your bill sir how would you like to pay? shall i get the ky jelly now? :o
« Reply #6 on: 27 August 2008, 22:25:41 »
What did you do bout the damaged pump faces....take them to a local machine shop for skimming?
Varche
    • Golf Estate
« Reply #7 on: 27 August 2008, 23:08:52 »
No, they don't have machine shops in these parts. Goat bells, olive baskets and asparagus trugs, mules. No call for it..
I have just got in from rubbing the surfaces flat with what I thought was valve grinding paste but turns out to be olive tapanade and a bread stick. Beggar that is two hours down the pan. ;D
Fortunately have the necessary parts courtesy of Mr Sassanach in my hamper. :y
We'll see what tomorrow brings.
varche
« Reply #8 on: 28 August 2008, 08:57:21 »
Think you will be surprised at your success.
As always with such things, you have found and confirmed the route cause of the fault (the failed thrust washer) and addressed it.
