Author Topic: Strange Traces Of Oil  (Read 8183 times)
amba
  • Medway towns
    • German V6
« on: 04 December 2019, 15:45:47 »
Opened bonnet today to top up screen wash and give engine usual cursory look ..noticed what I can only describe as an oil leak but its showing around the bagpipe connections only on the passenger side 2/4/6 bank where the top curved pipe from the throttle bodies joins the metal separator all around the large jubilee clip.
Really fresh oil and a enough to require wiping away with a rag but after short drive today it has reappeared.
Breathers were cleaned less than 1k ago along with fresh oil change ...never ever had it before and why is it only the 2/4/6 bank ??
Any guidance as to cause as will take it al apart and thoroughly clean but not for a while as have a drive upto Lincoln in the morning to Christmas Market with swtsmbo
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Strange Traces Of Oil
« Reply #1 on: 04 December 2019, 17:13:55 »
Could it be getting "thrown" there by the auxiliary belt or one of the pulleys after being picked up from elsewhere on the engine?
amba
  • Medway towns
    • German V6
« Reply #2 on: 04 December 2019, 17:23:15 »
Possibly but looking at how its covered the joint where jubilee and pie join I would of expected further oil splatters above the pipe...nothing at all.
Its almost like oil is leaking out of the bagpipe joint ...but that just cant be ..surely
« Reply #3 on: 04 December 2019, 17:26:24 »
They all do that...
Not unusual to find an inch of oil in the bagpipes.
amba
  • Medway towns
    • German V6
« Reply #4 on: 04 December 2019, 17:32:06 »
Thanks DG....never knew that ..So does oil lay in the bottom of the pipework and get sprayed around inside ?
Strange its only on 1 side so maybe the jubilee isnt fitting tight...will remove the entire pipework next week and give it all a good clean,then check jubilee clips
« Reply #5 on: 04 December 2019, 18:02:31 »
It drains down out of the breathers/plenum and through the throttle body ;)
Not sure if it is a side effect of engine wear or simply the closed breather system. Or both :-\
amba
  • Medway towns
    • German V6
« Reply #6 on: 04 December 2019, 18:25:52 »
Understand and thanks for concise explanation.
So the fact is leaking at union of top curved pipe and metal separator would indicate jubilee isn’t holding firm
« Reply #7 on: 04 December 2019, 20:53:55 »
Or that the pipe isn't fitted correctly... Easily misfitted as it snags on the bottom of the intake ;)
amba
  • Medway towns
    • German V6
« Reply #8 on: 04 December 2019, 22:32:30 »
Great thanks and after spending a few minutes with torch earlier have found the problem.
The 2/4/6 side intake pipe from the throttle body to the metal separator has a split and is causing oil to track down the back of the pipe and collect on the ridge where the jubilee fits.Doudt its repairable given where its split so need to source a replacement...…..time to post in wanted unless any body reading this can help
« Reply #9 on: 05 December 2019, 10:53:08 »
Get plenty of tape around it for the time being as it will also be acting as an air leak (unmetered air getting in)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #10 on: 05 December 2019, 14:19:55 »
If its the o/s one, Im pretty sure its the same on all V6,s.
« Reply #11 on: 05 December 2019, 15:14:35 »
2.5 and pre 98.5 3.0 are different and larger  :y
Migv6 le Frog Fan
« Reply #12 on: 05 December 2019, 15:34:17 »
Ah, I didn't know that. Still, gives more options than just getting one from a 3.2.
« Reply #13 on: 05 December 2019, 18:03:54 »
2.6/3.2 don't have a sensor fitted to them, so no hole for one...
Migv6 le Frog Fan
« Reply #14 on: 05 December 2019, 19:54:48 »
Nor does the o/s on the 2.5/ 3.0 iirc.
