Author Topic: Dash display unit  (Read 3224 times)
ChrisPee
  • Kent
    • Omega Select estate
Dash display unit
« on: 07 December 2019, 18:28:21 »
This has probably been asked a dozen times already but here goes.
My 97 2.0 car has virtually no pixels left working, is it better to replace rather than repair?
Also, I've seen several different part numbers, can anyone please help me out on code-necessity so I don't have to remove my dash first?
I know it needs to be removed for replacement, is there a thread I need to go to for swap-advise too?
Thanks in advance guys.  :y
ChrisPee
  • Kent
Re: Dash display unit
« Reply #1 on: 07 December 2019, 18:54:29 »
I found the 'how to remove the clocks panel' on page 9 of the maintenance guides  :y
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #2 on: 07 December 2019, 21:43:03 »
If you've got pixels missing it's probably an early 2 plug black/yellow type. Your chances of finding a fully working one is virtually nil so I'd use the later single grey plug type.
Looky here
http://www.omegaowners.com/forum/index.php?topic=136159.0
Read to the end as there are a couple of corrections to the wiring guide on the first page.
