Volvo V70 Drivers Door Problem
Started by Sir Tigger KC, 15 December 2019, 12:13:21
henryd
Quote from: Doctor Gollum on 16 December 2019, 16:01:53
Quote from: henryd on 16 December 2019, 12:24:34
have a butchers here
https://cdn4.pelicanparts.com/techarticles/Volvo-V70/74-INTERIOR-Front_Window_Regulator_Replacement/images_med/pic01.jpg
Also clearly bolted on ;) Removing the speaker might also improve visibility at the front of the door...
similar set up to the mk4 golf,I have one here in bits at the moment
other rides
Thanks Henry, but it's the wrong door unfortunately.  :(  That's the P1 (98-01) door and mines the P2 (02-07).
I'll pop the door card off again and take a photo...  :)
Have you a Haynes manual for it?
Quote from: Doctor Gollum on 16 December 2019, 17:23:53
No...
There's a few 'How to' videos on changing the window regulator, but the knackered window channel is by the hinges and as said the only access is through a small hole.  ::)
Door liner and glass out, then remove the channel and repair or replace.
At risk of repeating myself  ;)
Clear all the crap out of the way and you'll have all the access you need. Pull the door if it makes it easier to work on...
This is the same as my door and the small hatch at the front is where the knackered window channel is.  ::)
I'll have another look tomorrow if it's dry to see how it's fixed in.  :y
henryd
other rides
I pulled off the door card again this morning before the rain set in and removed the speaker as well.  :y
Unfortunately the window channel is pretty mangled and also is welded in, but I had a go at straightening it out anyway without success.  :-\
The skies darkened and the wind picked up, so I hastily put it all back together and beat a retreat before the heavens opened to fight another day!  :)
Luckily I don't think I'll need to open the window for a while anyway!  :D
Probably...  :-\
What a pisser and all because I didn't get round to sorting a minor problem with a £10 part!  ::)  :(
The moral of the story is....
Quote from: aaronjb on 19 December 2019, 09:54:18
Quote from: Sir Tigger QC on 19 December 2019, 09:36:27
Don't buy an Ovlov? ::)
For a sub £1000 workhorse banger it's a great car and there's not a spot of rust, which is pretty good for a 16 year old with 165k on the clock.  :y
Although the drive is uninspiring and the turning circle is crap, the 2.4 D5 is pretty lively and has plenty of grunt when needed.  I'd have another, but I'd try and find the AWD version or maybe the XC70, as it really should be RWD!   :)
