Author Topic: Coolant Hose Sourcing  (Read 6256 times)
Michael Bond
  • Langley, Slough, Berkshire
    • Omega 2.5 V6 (1995)
« on: 21 December 2019, 14:07:53 »
I have a leaking coolant hose on my Omega 2.5V6 (1995). It is the heater supply hose that runs from the rear of the engine to the interior bulkhead. I have identified it as GM part number 9129564 but have been unable to find anywhere to source one from despite intense internet searches. Ideally I would like a new one but would settle for a sound used one. Can anyone offer any advice as to how I might get one?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Coolant Hose Sourcing
« Reply #1 on: 21 December 2019, 14:30:50 »
hoses pic with part numbers clicky
so cross reference part numbers
is it this one clicky you want ?
  • Online Online
« Reply #2 on: 21 December 2019, 14:31:10 »
Have a rummage on ebay.com...  ;)
Michael Bond
« Reply #3 on: 21 December 2019, 15:51:56 »
Yes, I have identified the part. It is hose number 3 on the diagram that davethebuilder posted. This equates to GM part number 9129564. Unfortunately no one seems to actually have it for sale. I have tried ebay, amazon and multiple searches on google. There is some obscure site in Russia that appears to be selling it but I can't understand a word of Russian and there is no English version. I just wondered if anyone knew another source of such parts that may not be obvious. Does anyone know of anyone breaking down an old Omega 2.5 V6 with such parts for sale?
amba
  • Medway towns
    • German V6
« Reply #4 on: 21 December 2019, 16:27:26 »
Is it leaking along the pipe length or from the heater bulk head speed fit union ?
Reason I ask is I know the actual pipe has an internal diameter of 15mm.(..long story but a piece of copper pipe and 2 jubilee clips says it all..) so if its just the pipe you could cut and join it...just a thought ...failing that Im sure somebody will be breaking 1 if you ask admin to put up a "Wanted"
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #5 on: 21 December 2019, 16:29:57 »
Have you tried a Vauxhall dealer ?
amba
  • Medway towns
    • German V6
« Reply #6 on: 21 December 2019, 16:32:26 »
Try ...Omega52 ...off ebay or maybe our own..Serek...sure either would be able to help you
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 21 December 2019, 16:44:38 »
 Those pipes are /have become difficult to find, I haven't got any, and I'm sure serek hasn't got any either. :(
Hoof'land storeman.
Michael Bond
« Reply #8 on: 21 December 2019, 16:45:17 »
Yes, this is a good idea. I will do this if no success sourcing a new part. The leak is near the end without the connector so it should be possible so long as the old connector still functions without leaking after being removed and re-fitted.
amba
  • Medway towns
    • German V6
« Reply #9 on: 21 December 2019, 16:50:20 »
If the leak is in the pipe at the opposite end to the speed fit I would be inclined to cut out the damaged/leaking section square.then cut whats left in the middle and do as I did and add a short section of 15mm pipe...aluminium would be better as Im not sure if coolant has any effect on copper but it got me out of a problem until I could find a new hose.
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #10 on: 21 December 2019, 16:51:03 »
You can, if all else fails....try the silicone route,many companies like Demon Tweaks may well have what you need :-\ :y
Michael Bond
« Reply #11 on: 21 December 2019, 17:07:46 »
Thank you all. I think I will probably go with Amba's suggestion if I don't find one in the next few days. It will at least allow me to fix it until one pops up on Ebay one day.
amba
  • Medway towns
    • German V6
« Reply #12 on: 21 December 2019, 17:12:51 »
It worked for me 1 December when it let go...stayed like that until June I think with no ill effects
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #13 on: 21 December 2019, 18:54:18 »
Have you tried Google Translate to decode that Russian advert?
Ron,
Enceladus
  • London
« Reply #14 on: 22 December 2019, 03:05:48 »
Are you sure you have identified the correct part number? Have a look at the drawing here.
Might the problem hose be #10 9129576?
When I experienced a similar issue to you it was #2 on the drawing. This is the inlet pipe for the HBV that connects to a spigot at the rear of the engine in the well of the 'V'. It was split under the hose clip. That hose is 90466222 and Autovaux got it for me for £7.60+vat + delivery about 30 months ago.
Incidentally the leaking coolant nicely doused the coil pack, which gave up the ghost shortly after.
