Author Topic: 2001 Omega 2.2 DTI diesel started > stalled > will not start  (Read 3260 times)
Darius
    • Omega 2.2 diesel
My 2001 2.2 DTI had been sitting for a day or two.  I started it and moved it 50 yards - no problem.  An hour later I started it - no problem.  I moved off and I stalled it.  It then refused to start.
I cranked till I eventually flattened the battery.  I recharged the battery and tried the next day and it was exactly the same.
It has 1/3 tank of fuel. The glow light comes on as normal when I turn on the ignition.
I suspect fuel starvation not least because some years ago the fuel return pipe developed an air leak which emptied the fuel pipe.
Does the diesel fuel pump have a fuse?  I ask because the manual says Fuse 18 is for the fuel pump but there is no Fuse 18 inserted - the position is empty.  I wonder if Fuse 18 is for a petrol pump and so unused on a diesel?
Does it have a fuel cut-off switch?  If so stalling it might have given it a high g shock which tripped it.  The manual does not tell me it has one nor how to reset it.
All the fuses in the fuse box close to the battery are good.
Any thoughts will be appreciated.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: 2001 Omega 2.2 DTI diesel started > stalled > will not start
« Reply #1 on: 22 December 2019, 17:51:38 »
from  tolerancedata
start and charging fuses F9 10amp and F15 20amp
also an engine management fuse 20amp in the under bonnet relay box
don't  have my haynes joke book to hand sorry
Darius
    • Omega 2.2 diesel
« Reply #2 on: 23 December 2019, 16:35:03 »
Dave
Thanks.  All the fuses are OK so I am beginning to suspect the relay for the glow plugs or the fuel pump.
Darius
    • Omega 2.2 diesel
« Reply #3 on: 16 January 2020, 13:40:31 »
It was the fuel pump which had failed.  It got a new bit of electronics and all is now well.
    • 530D M Sport, 330i Coupe
« Reply #4 on: 16 January 2020, 18:15:00 »
The EDC failed, common Bosch VP44 pump fault :(
