3D Printer Chat
Started by aaronjb, 27 December 2019, 15:16:32
Viral_Jim
Quote from: TheBoy on 13 January 2026, 10:22:49
The standard hyper is card spool usually, not an issue, just make sure you don't damage the edges.
This is similar to what id seen online. I may end up printing some spool rings to sit round them - and to use up the w@nk filament we have left over.
Quote from: TheBoy on 13 January 2026, 10:25:23
Oh, and to protectb bed sheet coating, use so print spray. My preferred is3dlac but glue sticks, hairspray, whatever. Suspect you use something on ender anyway
Honestly I never have. Rightly or wrongly I'd always seen warping / poor bed adhesion to be a sign I needed to dial in my settings better (gluesticks being a common crutch in this scenario from what I've seen) and my ender came with a magnetic flexi bed sheet which I'd considered to be a semi-consumable that I would replace as and when, given they are <£10. Never needed to though - it looks a bit tired now, but still fully functional after 2 yrs.
That said, the K2 is going to print an order of magnitude faster than the ender, so additional stick would probably come in handy. Looking at the 3DLAC - do you need to spray the bed every time, or is it a bit like rainex where a coating is formed that you topup periodically? Also, can you spray it on and leave it? With cloud access I can see me printing from remote locations (think the office when I should be working, but I'm not), so having the printer ready to go would be a plus.
The glues help create a barrier between print and bed so can aid removal
For most materials, 3dlac is an infrequent spray, my last can lasted 2 years.
Quote from: TheBoy on 12 January 2026, 14:31:19
Yes, that space to left of top CFS is reserved for another when I can get one at a good price - I ain't paying £220 for one!
Thats now ordered, £179, which I'm happy with.
Viral_Jim
Quote from: TheBoy on 16 January 2026, 11:04:15
That's a beast of a setup, and good discount too, considering iirc the CFS on creality's site is £289 at full price. My k2 is currently in its box blocking up our hallway as I haven't had time to do anything with it since it turned up yesterday. Not sure where the 16kg of hyper PLA is going to live when it turns up sometime in the next hour  ;D
Quote from: Viral_Jim on 16 January 2026, 12:40:01
Print yourself an extension. :y
Viral_Jim
Well it took me nearly another two weeks to actually get setup and printing, but so far its worked flawlessly, setup was easy and so far everything I have done has been via the Creality Cloud app and website. I will need to use the standalone slicer at some point, but to be able to design in tinkercad and print from the app, is extremely useful (work laptop).
To date I haven't any Wifi issues and the speed and quality of prints are both next level compared to what I have been used to previously. To date I haven't printed much beyond enhancements to the printer itself - CFS riser and dessicant boxes, poop chute and bin etc. But not having to wait 24-48hrs for big prints has certainly opened up a lot of possibilities. Overall I can definitely recommend the regular K2 :y
Next stop is converting the old ender 3 into a laser engraver.... ;D
Viral_Jim
Ah, one question I did have TB, is do you have any sort of isolating feet for yours?
I'm just printing at the standard 100% but the printer doesn't half get a wobble on when going back and forth on narrow parts.
The K2 doesn't come with the extra feet like the K1 Max did.  TBH, it doesn't affect the amount of wobble.  Not sure about the standard K2, but the K2 Plus case a very rigid frame, far more rigid than the K1 Max, which does help a bit.
The wobble itself isn't necessarily a problem for the print and it's quality - that's why it does a bit of a shake test during calibration - but the furniture it sits on might not like it for long.
Mine is sat on a PLA printed drawer setup, with that having 2mm of TPU printed feet under it.
Oh, and I have some 0.6 and 0.8 nozzles turning up from ching chong. Allegedly genuine Creality parts.  Don't use pattern nozzles with hardened steel tips, they tend to blow the tips out.
That should speed up some of my longer prints.
I've also ordered 10 reels of Hyper PLA RFID for £84 delivered from Creality, because, well, errr, its a fettish.  The printer will soon gobble them up, esp with the bigger nozzles!
Can't remember if I said I had stick on RFID tags for my non RFID spools.  That works well - I know it only takes a few taps to manually enter on the printer, but RFID is proper lazy ;D
Viral_Jim
Quote from: TheBoy on 30 January 2026, 11:41:17
I am going to do this, in fact I ordered some, then found out there are multiple standards and ordered the wrong ones because I'm a bit simple. Returned with more are on order. I find the little screen on mine quite fiddly with my shovel hands, so the stickers would be better.  Also, some of us don't have the ability to have 16 rolls on the go at any one time  ;)
£8.40p per reel for the RFID stuff is a great price. Looking on the Creality store the best I can see is £19.99 with 30% off if you spend 10. Am I missing something?  :-\
The RFID type you need are MiFare Classic 1k.  In UK, I was struggling to get them for less than around 40p each in quantities less than 50.  Someone on Ebay doing 100 for about £22 delivered.  I've got a load coming from aliexpress, something like £9 for 80 - I can let you know the item number when they arrive and I've tested.
Creality's Ebay store is usually cheaper, and has a 20% off just about everything at the moment, which makes them hard to beat, although stock levels are always variable.  Also, I find they tend to arrive on the very last day of the timeframe suggested, so no good if in a hurry!
https://www.ebay.co.uk/str/ukcrealityofficialstore
The 20% code currently is FINALLY20 - they tend to have a 20% code every few weeks, so no need to massively stock up.
Viral_Jim
Quote from: TheBoy on 31 January 2026, 13:14:06
I ordered some off eGay and they work, but aren't cheap enough for me to want to use them as disposable.
I haven't yet found a way of doing multi colour printing of on my own designs out of tinkerCad. Well, I can print in two parts and glue them together obviously, but this seems like a faff compared to just getting the printer to do it. Do you know if there is a way of doing this? Whenever I do a multicolour model in tinkerCad, the stl just comes out as a single piece in a single colour.  :-\
Yes, the STL files is simply a set of triangles, nothing more.  Colour is done in the slicer, and you're in for another learning curve there.
In Creality Print, it's call painting, and they is a paint icon at the top.  This is a bit limited, but gives some options, like layer level painting, or fills etc.  Plenty on gayTube about Creality Print painting, which will explain better than a paragraph or 2 here.  I find it limited, and a pain to edit if you need to make a change, and often end up clearing all painting and starting again.  But its handy for first steps.
Additionally, and more usefully in my opinion, you can also paint at an object level.  Objects can be seperate models (though thats a dumb idea, as will cause massive pooping), or text that you add via the Text button at top, or "modifiers" (right like the model, then select modifiers, and the modifier shape).  The latter allows SVG file imports, so great for logos and simple pictures.
When painting at the object level, you need to change the view from "Global" to "Object", which is an option on the left of the screen, and it will list the colour against each object or modifier, which obviously you can change.
So, these are easy to create using the Layer Painting in Creality Print.  Just create the model in Tinkercad, and paint the top 3-5 layers as black.
Or painting using objects, create a flat 50x30x1mm rectangle, import into Creality Print, use the Test Tool to add the text, and change the colour of the Text object to Black:
Viral_Jim
That's useful to know thank you, I'm glad I wasn't missing something obvious in tinkercad.
I haven't played with the proper slicer yet, only the cloud based one and the phone app, so not sure if it's possible there but I will have a play at some point.
The main use case I've got is exactly as you described here, labels, raised text or similar so changing at a specific layer height should work just fine for me.  :y
