Author Topic: Corsa Knocking Noise  (Read 5589 times)
« on: 28 December 2019, 19:12:32 »
Cadged a lift with a mate earlier in his 08 Corsa that has an awful knocking noise from the front end.  :o
My mate is not slightly mechanically minded and has been told that it's the steering column?  So I'm just wondering if this sounds right?   ???
By the noises as we went over the bumps it could be any of a number of things, but I was wondering if a noisy steering column is a common Corsa thing?  :-\
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Corsa Knocking Noise
« Reply #1 on: 28 December 2019, 19:31:54 »
Drop links.  ???
« Reply #2 on: 28 December 2019, 19:36:30 »
Drop links.  ???
Yes, it sounded more like a suspension issue to me, but I've no experience with Corsas...  :-\
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #3 on: 28 December 2019, 19:39:07 »
 the steering column would be one of the last things to check  :o
anti roll bar drop links and bushes, broken coil springs are common
pinch bolts on the struts ,strut top mounts,
loose parts about to fall off ,particularly if it's been chaved up   ;D
he should get someone to check it as a matter of urgency !
« Reply #4 on: 28 December 2019, 19:45:41 »
He says he's had a mobile guy he uses look at it, and the steering column was the diagnoses.  :-\
It's not something I've heard of before hence my enquiry. Now you mention it though I bet it's a broken spring, as it was very noisy going over bumps and potholes.  :o
YZ250
« Reply #5 on: 28 December 2019, 19:47:17 »
My daughter's had a Corsa C and still has a D and the only clonking I've known was the drop links. Never known the steering to give any issues on either of hers but as drop links are so cheap it's worth him changing them anyway to eliminate them.  As Dave said, he could have it checked for any other faults while it's got a jack under it.  :y
« Reply #6 on: 28 December 2019, 19:50:33 »
I don't know to what extent the car was examined to be honest....  :-\
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #7 on: 28 December 2019, 19:52:22 »
If the "mobile guy" knew anything about cars,and it was the steering column loose .broken mounts etc ,he'd have advised to stop using the car immediately
by "mobile guy" perhaps he's someone who fits new screens to Iphones etc  ;D
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #8 on: 28 December 2019, 20:45:27 »
I’ll see if my popemobile guy will have a look at it for him with the grace of God.
Laying a rubber road.
« Reply #9 on: 28 December 2019, 21:02:27 »
My mate has a wing and prayer approach to car maintenance.....  ::)   ;D
Raeturbo
  • South Wales
« Reply #10 on: 28 December 2019, 21:12:30 »
God bless him  :y
Raeturbo
  • South Wales
« Reply #11 on: 28 December 2019, 21:19:01 »
I normally use Voodoo on my fleet ::) ::)
« Reply #12 on: 28 December 2019, 21:23:54 »
I make sure mine are in tip top condition by having a service and MOT done anally annually. 😁
Raeturbo
  • South Wales
« Reply #13 on: 28 December 2019, 21:35:35 »
Yearly isn’t so gay
Raeturbo
  • South Wales
« Reply #14 on: 28 December 2019, 21:36:06 »
And just as often :y
Page created in 0.023 seconds with 20 queries.
