Author Topic: interior light staying on  (Read 13618 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« on: 04 January 2020, 16:15:46 »
I'm having a problem with interior light staying lit all the time even when driving. Thought it might be a door light switch so checked for corrosion etc all seemed good and the puddle lights all illuminate and go off correctly .The only way was to unplug roof light unit
Any ideas thank you all
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
Re: interior light staying on
« Reply #1 on: 04 January 2020, 16:50:05 »
Had the same once. In my case it was the main light switch. Even though it was pushed in lights were on unless i held pressure on it. Solution was to change main light switch.
Toledodude1973
  • IPSWICH U.K.
« Reply #2 on: 04 January 2020, 17:42:24 »
Thanks i would have to purchase light switch to try ,any way of testing?
« Reply #3 on: 04 January 2020, 17:46:30 »
Before you buy anything, pull the light knob out and make sure it pushes fully home :y
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #4 on: 04 January 2020, 17:47:19 »
Try pushing/holding your current light switch firmly against the dash to see if the light goes out.
« Reply #5 on: 04 January 2020, 17:50:16 »
Mannen fra Norge, skriver han sakte. ;D
Toledodude1973
  • IPSWICH U.K.
« Reply #6 on: 04 January 2020, 18:07:44 »
just gave it a try but no joy :(
« Reply #7 on: 04 January 2020, 18:12:50 »
New switch time ;)
Toledodude1973
  • IPSWICH U.K.
« Reply #8 on: 04 January 2020, 18:22:18 »
couldnt be like a short in the light itself could it DG
« Reply #9 on: 04 January 2020, 18:26:34 »
Unlikely as that would blow the fuse, whereas switch wear/failure wouldn't necessarily  ;)
Toledodude1973
  • IPSWICH U.K.
« Reply #10 on: 04 January 2020, 18:31:15 »
ah right i'll post in wanted section ,guessing facelift 2002 omega elite are all the same
« Reply #11 on: 04 January 2020, 19:07:35 »
Yes, or any xenon equipped car ;)
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #12 on: 04 January 2020, 20:50:27 »
Ja Doctor Gollum. Skriver for sakte:p
« Reply #13 on: 04 January 2020, 20:54:39 »
 ;D
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« Reply #14 on: 05 January 2020, 09:19:13 »
Here is one for you:
https://www.ebay.co.uk/itm/T1229-Opel-Omega-B1-Light-switch-90460591-1998-2000cc-Gasoline-100kw/401885419481
Jan Suhr
Stockholm, Sweden
www.protouring.se
