Another MOT Pass
Started by Lizzie Zoom, 08 January 2020, 13:41:53
dave the builder
Quote from: Yodel-Odel-a-Eboy.com on 08 January 2020, 19:37:02
Quote from: dave the builder on 08 January 2020, 18:59:48
Congratulations on the pass Lizzie  :)
your's will be due it's first gearbox service ,if you ever do enough miles to get it up to 80k  ;D
TBE's probably needs some fresh ATF, seeing as its done 150k  ::)
if it aint broke  ;D
advice generally is either service it regularly or leave it alone ,
doing an ATF change on a high mile box that has never been serviced could well kill it
Quote from: dave the builder on 08 January 2020, 19:50:09
if it aint broke  ;D
Last AR35 on the daily had a fluid, filter change at 127K, it lasted just under another 100K.
Despite all the abuse that the AR35 in the Bullet had, I think it did well to last well over 230k.  But it was ultimately the cause of its demise.
That said, it was often sat at the lights with the brakes hard on, and the throttle just below where it would stall, for maximum acceleration ;D
mantaray
Does the AR25 box suffer the same? Only asking as I have just bought all the parts to change my ATF on a 150K box with no history.  It seems to be a bit sluggish on changing up and I was hoping an oil change might help.
2.6 CDX Auto Estate,
71 Opel Manta A Series 2.5 V6
Quote from: mantaray on 08 January 2020, 20:48:19
If it's bolted to a 2.6 you'll find they are all like that - hold onto the revs in the lower gears (when up to temp so not the normal warm up mode).
Migv6 le Frog Fan
To my knowledge, my AR35 has never been touched. Im currently undecided between fluid and filter change, or leave as is and stick another box in if it gives trouble.
It performs faultlessly at the moment, and I have other priorities on both cars, so a decision isn't high on the priority list.
ballcock50
Congratulations on the pass. Mine passed with little trouble again this year.
BazaJT
Well done Lizzie.At least the care and attention you lavish on it seems to be paying off. :y
Lizzie Zoom
Thanks all :y :y
I am now left wondering if I should have the gear box serviced or not given the various comments above.  What is the official Vx recommendation please?  What is the experienced gear box OOF'rs view on that?
I have no knowledge of what is right or wrong when it comes to gear boxes; never been trained in any aspect of them or touched them, apart from being a driver and knowing how to use them to the full! :D ;)
Rangie
Great news Lizzie, another year of luxurious motoring 😎
Rangie
#25
Quote from: Lizzie Zoom on 09 January 2020, 09:19:42
Thanks all :y :y
A lot of companies advised "sealed for life" re gearboxes ,but everyone I know myself included notices much smoother action if oil & filter change is carried out, I had the Subaru done when I bought it & the Range Rover was done last year they both are silk smooth in operation, personally for what it costs it is worth it.
Lizzie Zoom
Quote from: Rangie on 09 January 2020, 09:40:31
Thanks all :y :y
Thanks. :y
What can I expect to pay for this service please? ??? ;)
Rangie
Quote from: Lizzie Zoom on 09 January 2020, 11:18:12
Thanks all :y :y
Thanks. :y
The Range Rover was £279 .97 complete  the filter kit on its own was £133 so oil & labour was around £146.
The Subaru was around £145 all in.
That's pretty reasonable to keep your car on the road.
Lizzie Zoom
Quote from: Rangie on 09 January 2020, 13:57:59
Thanks all :y :y
Thanks. :y
Thanks Rangie :y :y :y
With TC perhaps I will get it cheaper with Vx, although I agree with STEMO that your cost with a Range Rover is very reasonable to keep a car going, especially when I consider how much I have spent already on my Omega! ::) ::) :D :y
