Author Topic: Changing central locking ECU.  (Read 4388 times)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« on: 26 January 2020, 11:08:05 »
When changing the C/L ECU,do you need to change the ignition barrel as well? tia :y
Re: Changing central locking ECU.
« Reply #1 on: 26 January 2020, 18:10:51 »
No, but it will need recoding to the car...
Why changing it?
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #2 on: 26 January 2020, 18:26:37 »
C/L ECU Fubar! ::)
« Reply #3 on: 26 January 2020, 19:17:09 »
How do you know?
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #4 on: 26 January 2020, 21:20:47 »
Serek :-\
« Reply #5 on: 27 January 2020, 10:18:13 »
Has the car in question ever had a check strap weld repair to the A post?
If yes, then it's as likely to be a wiring issue...
Either way, there's a couple of steps before blindly swapping the ecu out ;)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #6 on: 27 January 2020, 18:20:23 »
That's a yes to the check strap question....done by Serek a while ago :-\
« Reply #7 on: 27 January 2020, 18:47:55 »
Either the loom is damaged or it's not plugged in correctly.
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #8 on: 27 January 2020, 21:58:37 »
Looks OK plug wise,but you could well be right on the loom damage....looks like a trip up to Huntingdon for a bit of probing. :o
« Reply #9 on: 28 January 2020, 02:32:18 »
Ooh er :o
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #10 on: 28 January 2020, 11:31:48 »
Luckily...it's going to be the car that he'll be probing :o
