Author Topic: Wig-wag wiring  (Read 6334 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Wig-wag wiring
« on: 28 January 2020, 11:08:23 »
Restoring the ex-plod to something close to job spec, as there's a couple of shows I'd like to take it to. I've got a couple of Woodway EL13W alternating flash relays, and the associated wiring diagrams. So far I've got a lovely set up in the front (with the all important removable masters for road use), it works perfectly with two test bulbs.
Only thing is, when I connect it into the main beam wiring behind each light, and connect it all together - both main beam bulbs illuminate fully. Then they both flash a little brighter as the relay fires them. Presumably this is because the circuit is fully complete.
I've spliced into the loom (where it was originally removed from) - white wire each side. I've then reconnected the white wires, because otherwise (I think) I'll have no normal main beam at all. I've currently got the positive feed into the flasher relay coming through an 87 relay, if that can be altered to make things work properly?
Flasher unit has four connections -
12v + POSITIVE FEED IN
0v GND
A+  TO LH BULB
B+ TO RH BULB.
All fuses in the passenger compartment are intact and there's no sign of them having been previously cut.
There is the remains of a connection coming out of the yellow/white wire, behind the headlamp switch. There was a tiny bit of matching wire soldered into the RH main beam feed that I've now cut and spliced into myself... but I don't just want to connect it up willy nilly, I think the smoke will escape from the wires...
Re: Wig-wag wiring
« Reply #1 on: 28 January 2020, 13:58:54 »
Replace it with this:
https://www.ebay.co.uk/p/685128257?iid=202831664273&chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=202831664273&targetid=856645275288&device=c&mktype=pla&googleloc=9045816&poi=&campaignid=7643169318&mkgroupid=96891587948&rlsatarget=aud-629407025185:pla-856645275288&abcId=1139576&merchantid=101772886&gclid=CjwKCAiA1L_xBRA2EiwAgcLKA7wStEfuE-DycowKPXf1jI6W9DeUuANZPJUciaZhfhDRw9jqmoiZyBoCvXkQAvD_BwE
Works a treat, get two and that's the rear fogs done as well.
Being ex Thames valley, the cuts for the main beam flash are behind the passenger kick panel about level with the lower door hinge.
All my plod wiring stuff went with my estate, but white and white/ black are the wires in question, one each side.
Re: Wig-wag wiring
« Reply #2 on: 28 January 2020, 13:59:37 »
This might help/be of interest...
https://photos.app.goo.gl/hWnnCtudtvaBxthz8 :y
Re: Wig-wag wiring
« Reply #3 on: 28 January 2020, 22:46:21 »
Doc - you're a superstar. Thank you! :y
I've had a very nice email from the chaps at Woodway who suggest I may be able to fit a couple of diodes to solve the problem. If not I will replace it with the linked item...
(Who doesn't love flashy lights!)
Re: Wig-wag wiring
« Reply #4 on: 07 February 2020, 19:54:20 »
Updates. The fronts are wired with diodes and are working perfectly.
The rear fogs however are baffling. I've replicated the front precisely. Ran two wires, one to each fog. Intercepted the blue/ black wire. Put the diodes in and tested. When the blue/black is separated, they work perfectly. When it's all connected up, the electrickery takes precisely no notice of the diodes and lights both bulbs together. I've tried swapping components every which way and it's the same. I tried a Paddington Bear stare. And a good dose of Anglo-Saxon. Still no success... I wonder how on earth to get it to work correctly.
Re: Wig-wag wiring
« Reply #5 on: 07 February 2020, 20:37:25 »
You need to split the common feed before it goes to the light.
That's another reason why I went with the flasher units I used ;)
Re: Wig-wag wiring
« Reply #6 on: 08 February 2020, 09:13:19 »
;) Gotcha!
