Author Topic: X20xev camshaft state...  (Read 2703 times)
jimjimanta
  • hellas
    • opel omega b , opel manta
« on: 29 January 2020, 20:33:39 »
I have a opel omega b with x20xev engine.
I recently repaired the engine .
Probably, I put the camshaft pulley  in the wrong place ...
The camshaft pulley have two states, lock with camshaft.
How are they going and how important is their position?
Enceladus
  • London
Re: X20xev camshaft state...
« Reply #1 on: 30 January 2020, 03:54:52 »
Pulley? I believe you mean the camshaft sprockets which confusingly are the same for both shafts. Each sprocket has a pair of position slots for the locating dowel, intake and exhaust. Assuming you have removed the sprockets from the shafts then the drawing here might help to determine which position slot is for the intake camshaft and which for the exhaust camshaft,
The valve timing will be wrong if the sprocket dowels are incorrect.
« Last Edit: 30 January 2020, 04:03:18 by Enceladus »
jimjimanta
  • hellas
« Reply #2 on: 30 January 2020, 08:07:40 »
Yeah, that's what I'm looking for!
In the drawing, in black it shows the wedge;
