Author Topic: Toe Front/Rear  (Read 6745 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Toe Front/Rear
« on: 02 February 2020, 16:17:39 »
Once again, front camber -1degree, 1minute how about toe in front/rear. Tomorrow is the day...
Re: Toe Front/Rear
« Reply #1 on: 02 February 2020, 16:23:26 »
Front toe in 0.03, same both sides...
Rear toe whatever they can get as it adjusts with Camber, but ideally same side to side and thrust angle MUST UNDER ANY CIRCUMSTANCES BE ZERO. Accept nothing else.  :y
polilara
  • Finland
Re: Toe Front/Rear
« Reply #2 on: 02 February 2020, 16:33:51 »
Thanks DG, what is the dimension Zero degree 0.3 minutes?? sorry, not clear... Rear side OK (understood).
Re: Toe Front/Rear
« Reply #3 on: 02 February 2020, 16:35:08 »
FRONT TOE, NEGATIVE.  ::)
polilara
  • Finland
Re: Toe Front/Rear
« Reply #4 on: 02 February 2020, 16:40:07 »
Yes, negative = toe in, but what does this mean? 0.03
Re: Toe Front/Rear
« Reply #5 on: 02 February 2020, 17:07:05 »
-Zero degrees, three minutes ::)
Similarly camber is - 1 degree, ten minutes...
polilara
  • Finland
Re: Toe Front/Rear
« Reply #6 on: 02 February 2020, 17:11:06 »
OK, clear, always so difficult...
And Thanks!
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Toe Front/Rear
« Reply #7 on: 02 February 2020, 17:18:17 »
And Thanks!
Still much better than me trying to translate it into Finnish ;) :y
Re: Toe Front/Rear
« Reply #8 on: 02 February 2020, 18:01:16 »
And Thanks!
Indeed, and it would be alot easier if not repeated 38 million times ;D
I just hope the damn drives well...
polilara
  • Finland
Re: Toe Front/Rear
« Reply #9 on: 02 February 2020, 18:09:09 »
Finnish is easy:
Toe in = auraus
Toe out= haritus
Next time you know...
  • Online Online
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Toe Front/Rear
« Reply #10 on: 03 February 2020, 10:38:16 »
when expressed as decimals, 3 minutes or 1 degree 10 minutes are NOT 0.03° or 1.10°!
1 minute is 0.0166666667°. Aproximately...........
Re: Toe Front/Rear
« Reply #11 on: 03 February 2020, 12:33:39 »
Ok, for clarity, please use the following link as a basis for Omega geometry...
https://photos.app.goo.gl/X8LNjcVof8pqodKV9
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: Toe Front/Rear
« Reply #12 on: 03 February 2020, 14:53:59 »
Are these the WIM recommended settings or the factory settings?
What does the 'cross' figure in the camber and castor refer to?
Re: Toe Front/Rear
« Reply #13 on: 03 February 2020, 15:57:13 »
They're not the Factory settings, which have been proven to cause excessive tyre wear.
I suspect the cross figures are the relative average across the car.
These were from the last time I had my plod estate set up, so poly front bushes and probably ATP wishbones, along with poly donuts and solid rear diff mounts, but otherwise factory Plod with working self levelling.
Car at this point had done 262k miles and had been rear ended three times and had two frontal impacts. Hence the caveat that they should be a reasonable target.
That said it drove like a missile and set up as above would see even tyre wear on all four tyres.
polilara
  • Finland
Re: Toe Front/Rear
« Reply #14 on: 03 February 2020, 16:47:29 »
Too many things at the same time but this is how it is now, row by row, do I have to change something. I can go back there, he is my "friend" and not expensive at all.
Page created in 0.026 seconds with 20 queries.
