Author Topic: front passenger window switch  (Read 19218 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« on: 05 February 2020, 21:55:50 »
After interior light / switch problem solved i now have another the passenger front window switch no longer operates the window . I can operate it from drivers side so motor seems ok. After reading back on here is it more than just the passenger switch , any thoughts please thank you
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Re: front passenger window switch
« Reply #1 on: 05 February 2020, 23:41:09 »
Passenger switch is the likeliest candidate if it works from the driver side.  ;)
Toledodude1973
  • IPSWICH U.K.
« Reply #2 on: 06 February 2020, 18:22:48 »
Thanks DG  tried removing switch to maybe clean the contacts but could only get main piece out and not able to disconnect the grey plug bit to allow me to see it in the light, is there a knack to this?
« Reply #3 on: 06 February 2020, 21:01:30 »
It's only clipped in...
Toledodude1973
  • IPSWICH U.K.
« Reply #4 on: 07 February 2020, 18:42:08 »
Took switch out and apart,cleaned contacts ,reassembled and then tried it in car.  Firstly didn't help with window operation, but after operating nearside front window using drivers side window switch it  would go down but not up again!    Strangely to my luck/surprise the only way to get window to go up was to have drivers door open ,then operate drivers side window switch ! Passenger switch still wouldn't work even with drivers door open ......any ideas please
« Reply #5 on: 07 February 2020, 18:48:44 »
OK, you have a break in the passenger feed from the drivers door.
Firstly check that the plug is correctly seated and test again.
Then...
Unplug the door and peel back the rubber boot, the break in the insulation should become obvious.
Removing the door will significantly improve access, two pins and the check strap, but you will need an assistant as it's heavy. Remove the door card if you do this in case you need access inside the door
Toledodude1973
  • IPSWICH U.K.
« Reply #6 on: 07 February 2020, 18:54:11 »
Thankyou i will have a look tomorrow ,hopefully without removing door :-\
Toledodude1973
  • IPSWICH U.K.
« Reply #7 on: 08 February 2020, 18:14:06 »
Peeled back rubber cover near door hinge to expose wiring,all seemed ok , i've now realised if i raise /lower switch on drivers side i can move passenger window up and down (fiddling quickish with switch as such)with drivers door shut ,passenger switch still no go ,any thoughts please :-\
« Reply #8 on: 08 February 2020, 23:35:16 »
Inspect the loom and plug better as there is clearly a break in the loom at the drivers door.
Toledodude1973
  • IPSWICH U.K.
« Reply #9 on: 09 February 2020, 18:54:39 »
Doc when you say unplug loom does one end come away from door? i took black round cover off and exposed bunch of cables after peeling back rubber towards car pillar but had limited room for inspection ,i really want to avoid door off as help is not always forthcoming ::) thanks again
« Reply #10 on: 09 February 2020, 19:20:13 »
Doc when you say unplug loom does one end come away from door?  ....
 :y Yes  :)
Toledodude1973
  • IPSWICH U.K.
« Reply #11 on: 09 February 2020, 19:30:35 »
Andy is it just pull on the black round plastic piece or does it screw out ,as all i could do was take outer cap off? thanks
Toledodude1973
  • IPSWICH U.K.
« Reply #12 on: 09 February 2020, 19:35:08 »
Don't suppose anyone has picture with loom unplugged .......i know i'm pushing it now ;)
« Reply #13 on: 09 February 2020, 19:39:51 »
It's been a while since I had my Omega, but IIRC the screw collar holds the plug in position ie you undo the collar so far & then the plug pulls out
Toledodude1973
  • IPSWICH U.K.
« Reply #14 on: 09 February 2020, 20:02:35 »
Thanks Andy i'll give it a try  :y
