Author Topic: Any views on the Honda Accord estate?  (Read 23911 times)
Keith ABS
  • Maldon Essex
Re: Any views on the Honda Accord estate?
« Reply #30 on: 24 February 2020, 07:02:31 »
 I passed my advanced driving test using the left foot to brake the auto Senator I had at the time :y
« Reply #31 on: 24 February 2020, 08:08:36 »
I did a speed awareness course years ago when you went out in a car. The instructor gave me the same BS about the possibility of pressing both pedals when he saw me left foot braking.
« Reply #32 on: 24 February 2020, 11:00:21 »
People who use the correct method of one foot will continue to do so, as will people who use the wrong method. No use either trying to influence the other, really.  ;D
« Last Edit: 24 February 2020, 11:06:48 by STEMO »
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #33 on: 24 February 2020, 11:15:53 »
I don't think you can say that either is right or wrong. If people use the one that works best for them and they drive safely while doing so then there isn't a right or wrong way.
Modern F1 cars  only have two pedals, and some F1 drivers use one foot and others use both.
« Reply #34 on: 24 February 2020, 11:22:51 »
F1 drivers apart, one of the reasons I read why you shouldn't do it is because you risk giving the driver behind contra-indications by driving with your left foot slightly touching the brake pedal, thus putting your brake lights on. I don't expect that anyone on here would do that, I'm talking about mere mortals.
I know a driving examiner who walks his dog at the same time as me occasionally. I'll ask him what the situation regarding the automatic test is when I see him next.
« Reply #35 on: 24 February 2020, 11:31:44 »
... I'll ask him what the situation regarding the automatic test is when I see him next.
He'll say the world will end if you use both feet  ::) ::) ;)
Migv6 le Frog Fan
« Reply #36 on: 24 February 2020, 11:41:27 »
I don't drive along with my left foot hovering over the brake pedal so that's not going to happen. Either way is perfectly fine, its just what you get used to I suppose.
« Reply #37 on: 24 February 2020, 12:22:30 »
Extend that logic a bit and you'd be suggesting that everyone who drives a manual car must go through clutches every few thousand miles because they're always lightly touching the clutch, causing it to slip..
..that said, I've known a few women who habitually drove in six-inch heels who did exactly that, for exactly that reason..
« Reply #38 on: 24 February 2020, 12:23:02 »
Have you caught the rolling eye smiley virus from Al?  ;D
He definitely won't say that, as it is obviously incorrect. He may say it's frowned upon or even a fail. He may say it's perfectly fine, we'll see.
« Last Edit: 24 February 2020, 12:24:50 by STEMO »
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #39 on: 24 February 2020, 12:25:22 »
lots of drivers already move their right foot onto the brake pedal enough to illuminate the lights, but not the brakes. The driver behind then has no indication when they actually begin to brake. This is particularly common when turning left: lift off, touch the brake pedal, indicate(sometimes), 3m later turn in, then stomp the pedal to the floor when they finally spot the other traffic in the turning.
« Reply #40 on: 24 February 2020, 12:28:21 »
That, at least, is an indication that you intend to slow down. Brake lights while travelling along with traffic would give the wrong indication.
« Reply #41 on: 24 February 2020, 18:14:29 »
But when you only have two pedals, which are never used at the same time, using both feet makes more sense.
Now that's not always true, and moreso now that just about everything is turbocharged.
« Reply #42 on: 24 February 2020, 18:44:44 »
I thought I'd try using two feet when I went out this aft, it felt really uncomfortable and just wrong. When I used my left foot for the clutch, it was always on the left hand side of the footwell. But with the brake pedal being more towards the middle, I felt the need to turn towards the drivers side window.  ;D
« Reply #43 on: 24 February 2020, 18:47:22 »
For all those against left foot braking  ..... have you tried pressing both pedals at the same time? If you have a fly-by-wire throttle (which most cars have these days) then you'll find that after a very short time, the throttle effectively gets switched off  ;)
« Reply #44 on: 24 February 2020, 18:49:47 »
when practising left foot braking ..... brake as you would normally do with your right, but cover the pedal with your left at the same time  :y
Page created in 0.022 seconds with 20 queries.
