Author Topic: Raising jaguar XFR headlights.  (Read 8243 times)
Re: Raising jaguar XFR headlights.
« Reply #15 on: 19 February 2020, 08:36:37 »
Should adjustment be made in a clockwise or anti-clockwise direction?
The neanderthal knuckledraggers  at Duckworth Jaguar lowered the beam to satisfy the MOT criteria. The headlights now shine about 4 feet in front of the car making it dangerous to drive in the dark.
Go on then I will dare to ask the questions others dare not ask.
1.Are you a trained MOT tester?
2, Was there a quality issue with the factory settings, i.e. not set as per MDT settings?
3. When you have adjusted your lights up is there a vague possibility that you will then be one of those folk with blinding lights at nightime?
4. Do you do enough driving at night on unknown roads to need 100% lights?
5. Have you had your eyes tested?
I can check exactly what it was set to in the factory......
......as for training, you must have forgotten what the garage techs are like here  ;D ;D :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #16 on: 19 February 2020, 10:36:57 »
Some cars lights aren't fit for purpose. Vectra C facelift for example. Adjusted to pass the MoT, they don't actually illuminate the road ahead.
the MOT requirement is that you don't dazzle oncoming traffic.
The machine that the tester uses highlights the beam pattern and the areas where it isn't allowed to fall. When he adjusts the lights(it's one of the few things he is allowed to adjust, so insist if he refuses) all he is doing is moving the beam out of the proscribed areas, which often results in lights that don't work well for the driver. It is perfectly possible to adjust them to both requirements, but that does take some fiddling around.
I think a 7" round headlamp with a good quality H4 bulb still compares well to more complicated modern lamps.
« Reply #17 on: 19 February 2020, 11:51:36 »
Blimey, not aligned with you there! ;) :y
« Reply #18 on: 19 February 2020, 12:50:37 »
Two informative statements here. :y
Every year the MOT guy makes sure I don't dazzle other drivers by setting the headlight beams so low they are dangerous. I have 20/10 vision but I still need some light to see with.
So, every year following the MOT,  I spend precious time trying to get the lights raised so they light up the road ahead rather than right in front of the car.
The way I set them not once have I been flashed ( no not that sort of flashed ::) ) by other drivers. I just wish the MOT testers would f*ucking leave well alone. :)
« Reply #19 on: 19 February 2020, 12:53:32 »
I refer the honourable gentleman to reply 18. :)
« Reply #20 on: 19 February 2020, 13:03:03 »
I had thought of applying,as Im certainly a weirdo. He seems an arrogant little nob though, so I might get fired in the first week for giving him a slap.
You reckon you'd make it to the front of the queue that soon?
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #21 on: 19 February 2020, 16:39:26 »
OK, interesting answers.
Next question. My Golf7 has bi xenons and Lord Opti would describe the aim as set too low. I joined a Golf forum ( not a patch on OOF) and the view was the lights were poor by design as a backlash against xenons . Plus they weren’t adjustable except by a dealer.
So asking a knowledgeable forum. Can my Golf7 lights be adjusted and is it dealer only?
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #22 on: 19 February 2020, 19:05:39 »
Much like the emissions on your Golf :-X
You're not wrong there Doc. The dipped beam on mine are cack. Heads are good though. :y
« Reply #23 on: 19 February 2020, 19:08:54 »
Yep....utter shite on the mighty Signum.
« Reply #24 on: 19 February 2020, 19:40:50 »
You should all take into account the fact that you are getting on in years and your eyesight isn't what it used to be. I can see perfectly with the standard lights on my astra.
ronnyd
« Reply #25 on: 19 February 2020, 20:21:23 »
You may have a valid point there young man. ;D
« Reply #26 on: 22 February 2020, 11:08:12 »
Remember that all bulbs degrade from the moment they are first used. And I mean all, be it halogen, HID or LED.
So if your bulbs are a few years old, seem pretty bright to look at, seem "ok-ish" on the road with no other traffic, but absolutely useless when there is oncoming traffic, you might want to consider new bulbs.  Unless you own a newer Jag XJ, in which case its easier to replace the car.
« Reply #27 on: 24 February 2020, 07:40:56 »
Just look for the manual adjusters, bound to be some
