Author Topic: sealed lead acid batteries  (Read 8706 times)
« on: 21 February 2020, 22:38:23 »
long story  .... very short
My Mum has/had a 4 yr old motorbility scooter that was semi drowned in a recent flood. Unfortunately I didn't get chance to do anything with it sooner but last night I stripped the two battery cases (2x12v batteries in series) to find two batteries similar to these clicky Each battery showed next to the square root of f*** voltage wise. They have both been on a dumb battery charger over night .... 1 looks to be showing signs of taking a charge, but the other is showing about 6 volts.
Is the expert opinion that both batteries are beyond redemption or is there a chance of recovery?
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
Re: sealed lead acid batteries
« Reply #1 on: 22 February 2020, 01:06:53 »
Well, you don’t want her to get stuck so you can’t chance it. They will never be as good as they were even if they do charge up, however I’ve seen  batteries like that cheaper than that.
« Last Edit: 22 February 2020, 01:11:48 by Raeturbo »
Laying a rubber road.
Raeturbo
  • South Wales
« Reply #2 on: 22 February 2020, 01:10:10 »
« Last Edit: 22 February 2020, 01:12:14 by Raeturbo »
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #3 on: 22 February 2020, 01:50:57 »
Not covered by house/contents insurance, Andy?
Ron.
« Reply #4 on: 22 February 2020, 06:43:16 »
She lost confidence with it & won't use it it.
I just picked a similar battery from the web to show what type  ;)
« Reply #5 on: 22 February 2020, 06:44:08 »
« Reply #6 on: 22 February 2020, 06:45:37 »
Ron.
Unfortunately not. Ironically this replaced one from Boxing Day 2015 when they were flooded
« Reply #7 on: 22 February 2020, 08:39:00 »
If the batteries are 5 years old they are likely not worth trying to salvage.
Sometimes you can wake them up by applying a higher voltage with a current limit until they start taking charge - i.e. by putting a bench PSU across them set to maybe 30V at a 0.5A current limit and just leaving it until they start drawing current. As said, they'll never be dependable so only worth doing just to test the rest of the scooter IMHO.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #8 on: 22 February 2020, 09:57:54 »
Kevin makes a good point. Can you test the rest of the vehicle before you spend money on batteries? I assume these things have charging gubbins, a simple ECU/speed controller etc, none of which are likely to be thankful for a dip!  :-\
« Reply #9 on: 22 February 2020, 11:25:49 »
At best, you can possibly get them to take a charge using the shock method, but will never take decent capacity.
I'd just replace, likes of mds battery sell a wide variety of smaller batts, although they aren't the cheapest any more.
« Reply #10 on: 22 February 2020, 12:45:45 »
The speed controller is at the top of the 'steering column' so didn't get set but the water came about level with the socket for the charger  :(
Unfortunately I don't have access to a suitable power supply other than standard battery chargers.
« Reply #11 on: 22 February 2020, 12:46:56 »
There's a place local to me that does various batteries ..... I'll get a price
« Reply #12 on: 22 February 2020, 12:48:04 »
What make is it, as batteries vary greatly.  ;)
« Reply #13 on: 22 February 2020, 12:49:31 »
Thanks. I thought they'd be toast.  :(
The scooter had only been driven about 100 yrs....
« Reply #14 on: 22 February 2020, 12:51:08 »
The batteries or the scooter? I'm at work so can't answer either ..  ;D
The batteries are Chinese
Found a photo of scooter & it's a Shoprider..... in blue  ;D
« Last Edit: 22 February 2020, 12:54:34 by Andy B »
