Author Topic: sealed lead acid batteries  (Read 8703 times)
Re: sealed lead acid batteries
« Reply #15 on: 22 February 2020, 13:09:48 »
In that case, pretty basic wet acid batteries...
Ergo, equally basic electrical bits on it ;)
Some of the newer lithium powered scooters would probably become scrap if submerged... Presuming the battery fires hadn't melted it first.
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #16 on: 22 February 2020, 13:30:53 »
We have got two scooters here. One the Shoprider ( Paris) has brand new batteries  but developed a fault due to offroading! If you were closer you could have tried them.
Keith ABS
  • Maldon Essex
« Reply #17 on: 22 February 2020, 16:53:34 »
 It is general practice to replace batteries together as a half good one can cause a new one to become NFG in a short amount of time
« Reply #18 on: 22 February 2020, 19:59:11 »
Thanks  :y
« Reply #19 on: 22 February 2020, 20:01:46 »
Thanks for all the replies.
Just got home & had a look at the state of each after about 36 hours on a charger. One is reading about 10 volts & t'other about 6 ...... Conclusion is they're fubar'd  :(
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #20 on: 22 February 2020, 21:32:29 »
If the batteries are 5 years old they are likely not worth trying to salvage.
Sometimes you can wake them up by applying a higher voltage with a current limit until they start taking charge - i.e. by putting a bench PSU across them set to maybe 30V at a 0.5A current limit and just leaving it until they start drawing current. As said, they'll never be dependable so only worth doing just to test the rest of the scooter IMHO.
Thanks. I thought they'd be toast.  :(
The scooter had only been driven about 100 yrs....
Should imagine they would be after so long. ;D
« Reply #21 on: 22 February 2020, 22:11:57 »
 Well done Ronny  ..... you spotted my deliberate mistake  ;D ;D
« Reply #22 on: 23 February 2020, 09:49:56 »
This reminds me that a valuable amount of space in my garage is being taken up by the Grandmother-in-law's scooter - probably in a similar state by now.
I know the batteries did recover at one point because I very nearly put it on its' side when "testing" it up and down the cul-de-sac. :-[
Needs lower C-of-G. ;D
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #23 on: 23 February 2020, 10:49:46 »
bigger batteries would do that.......
« Reply #24 on: 23 February 2020, 12:42:13 »
.. and while you're at it, it'd be rude not to fit a bigger motor... ::)
  • Chatham, Kent
« Reply #25 on: 24 February 2020, 10:46:10 »
then better tyres, and the wheels are probably proprietory so custom machined aluminium wheels - sorry, billet rims -would be justified.
And who could resist a muti-colour candy paint job? With ghost flames, obviously 8)
« Reply #26 on: 24 February 2020, 11:37:41 »
;D ;D ;D
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #27 on: 24 February 2020, 12:46:04 »
Try this guy for some batteries Andy, he seems to have made progress :D 8)
https://www.youtube.com/watch?v=gWYRhaOd1PE
other rides
« Reply #28 on: 24 February 2020, 13:59:16 »
 ;D ;D ;D ;D ;D
