Author Topic: LED Headlight  (Read 12925 times)
WHITE OMEGA
  • Damascus-Syria
    • Opel Omega 2.2 2002
LED Headlight
« on: 26 February 2020, 22:30:08 »
Hello all
Any one has ever fitted an LED bulb into an Xenon 2002 headlight.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: LED Headlight
« Reply #1 on: 27 February 2020, 18:34:03 »
pretty sure its not legal to do so in the uk to either a hid or standard headlight.not sure about where you are thou ?
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: LED Headlight
« Reply #2 on: 27 February 2020, 20:04:27 »
Profile says Damascus  ;)
cam.in.head
  • West yorkshire
Re: LED Headlight
« Reply #3 on: 27 February 2020, 20:51:42 »
i saw that but not sure whats legal or not over there .we certainly cant fit leds to non led lights here .
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: LED Headlight
« Reply #4 on: 28 February 2020, 00:37:44 »
Why not?
Ron.
Re: LED Headlight
« Reply #5 on: 28 February 2020, 06:19:27 »
Why not?
Ron.
Because the way the light unit functions varies from bulb (light source) type to type.
What's good for an open 55w halogen bulb is unlikely to work with an led bulb.
Dipped beam on a facelift Omega may technically work, as the design incorporates a focal lens rather than a reflector... but don't expect road legal/mot results.
Also large led bulbs generate a lot of heat, so the bulb may not actually fit within the housing.
Bigron
  • Witham, Essex
Re: LED Headlight
« Reply #6 on: 28 February 2020, 06:37:02 »
Thanks DG for a comprehensive and clear answer - I knew you would know. :y
Ron.
WHITE OMEGA
  • Damascus-Syria
Re: LED Headlight
« Reply #7 on: 28 February 2020, 19:58:58 »
Thanks all... Any headlight is legal here as long as its giving light.
Back to my original problem .. omegas xenon headlight seems to be very poor... I searched google and found some used bixenon which seem very complex work to fit , and i am not very sure about the results. any suggestion would be appreciated.
Re: LED Headlight
« Reply #8 on: 28 February 2020, 21:22:46 »
Are you 100% certain that your car has xenons?
Visually, the facelift lights look the same regardless of bulbs fitted.
On the top of the light unit is a white label which lists all the bulbs in that unit.
If you see D2S then they will be xenon, but don't be surprised if you see H7.
Have a look and report back :y
WHITE OMEGA
  • Damascus-Syria
Re: LED Headlight
« Reply #9 on: 29 February 2020, 09:29:29 »
Yes I am sure it's xenon. I found on YouTube some videos for bixenon swap,it seems a lot of work , and i am not sure about the results. Any plug and play swap do you guys think of.
Re: LED Headlight
« Reply #10 on: 29 February 2020, 09:36:37 »
New bulbs should sort it. Wouldn't bother messing around trying to retrofit summat which won't fit/work...
  • Auckland
    • Mazda MPV
Re: LED Headlight
« Reply #11 on: 29 February 2020, 09:54:56 »
The D2S HID lamps do lose output as they age. Fitting new ones may help (if they are good ones)(not Chinese fakes).
The plastic lenses go yellow in the sun. You can polish the lenses to remove the yellow surface layer..
The Omega only has HID dip beam. High beam is halogen. I found that it helped when I fitted 'bright white' halogen lamps to high beam to get a closer match to the colour of the dip beam.
Re: LED Headlight
« Reply #12 on: 29 February 2020, 12:52:04 »
Ignoring all legalities which may or may not apply in certain areas...
An aftermarket LED bulb will not fit a D2S light fitting.  They will fit a halogen unit, but you may have to leave the read cover off (bad move), due to the size of the bulb drivers.  Most current generation LEDs don't have active fans, but all previous generation do.  All benefit from airflow, which is why as an aftermarket fitment, they aren't ideal.
Ignoring the marketing BS, its been tested time and time again that at about 25m, quality HIDs have the highest light output compared to (aftermarket) LED and halogen, but beaten by laser as fitted to the latest high end cars (and not to be confused with Osrams "laser" range which is their marketing for their brighter HIDs).
The Omega HIDs are not too bad TBH, but need clean lenses, clean projector unit (which gets dusty if driven without the rubber cover on the back), and newish, quality bulbs, such as Osram and a temp of about 4.2-4.5k.  Halogen bulbs also degrade, so if the main beam is poor, put in new, quality halogen bulbs.
Obviously, show lights, like the whiter halogens, or the 6k and higher HIDs actually reduce illumination, so if you are after a certain look, there will always be a compromise between looks and function.
A bi-xenon conversion for an Omega would be a good compromise, but would be a tricky job.
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
Re: LED Headlight
« Reply #13 on: 01 March 2020, 07:34:12 »
The reason LED retrofitting doesn't work is plain geometry.
The reflector and shield in low beam has its geometry set up for a normal bulb where the source of light comes from the center. With LED's the source of light is off center and the reflector isn't constructed for that and you get a light beam that goes all over the place.
I have run with Low beam LED's on my Omega and it get a bright white light. In this case this car has H7/H1 bulbs, no XENON, so it was an easy fit. For High beam I also have LED's and they give a very good bright light and reaches far longer than the standard Halogen bulbs.
I have high quality LED's that cost around €100 for a pair and they have built in fans.
New cars with LED's have a proper reflector made for LED's
Jan Suhr
Stockholm, Sweden
www.protouring.se
luizvivas
  • Belo Horizonte, MG, Brazil
  • 92/93 Toulon Green 1-5-3-6-2-4
    • Omega CD 3.0 Turbo
Re: LED Headlight
« Reply #14 on: 14 March 2020, 14:30:53 »
I am interested in this subject. I love xenon. It is forbidden for old cars here, but many use it, because there are still roads, streets and avenues with bad pavement. I use Philips Diamond Vision lamps in low, high and fog lights. The possible option to legalize until 2021 are leds. Is it true that there are leds for headlights without a projector?
Powered by C30NE
