Author Topic: Need Help  (Read 2352 times)
dokolenkov
  • Uk
    • omega 2 ecotec 16v
Need Help
« on: 16 March 2020, 16:07:16 »
Hi sometime ago  I took Omega 2.0 Ecotec to Bulgaria to use as holiday car while there. The roads are atrocious and obviously the front suspention developed  kncking and ratling noises  So my Q.is What exactliy I need to change? Also because A/Con.not being used often the chill has disapeared. I did regassed the system but it worked for short time only looks like some seal has dried and dose not keep the gas in So my second Q is what I need to change. Thank you in advance
  • Online Online
Re: Need Help
« Reply #1 on: 16 March 2020, 17:14:39 »
Drop links first.
Normally I would suggest simply going through the suspension and renewing everything, but I suspect that you will have better use for the €800-1,000 that requires to do properly.
Likewise the condenser is your likely culprit for the aircon leak, but again, this is a €1-200 irrelevance.
Steveh
  • Debyshire UK
    • Omega 2L 16V
Re: Need Help
« Reply #2 on: 17 March 2020, 15:11:14 »
Had a coil spring break on mine once bit snapped off near the top and was rattling worth checking if youve been on rough roads.
