Author Topic: How Much Coolant You Can Drain from Radiator "Bottom Plug"  (Read 7467 times)
polilara
  • Online Online
  • Finland
    • 2.6 Y26SE Elegance 2001
Just changing coolant and wondering how many times I have to flush to get everything out?
Re: How Much Coolant You Can Drain from Radiator "Bottom Plug"
« Reply #1 on: 17 March 2020, 08:16:22 »
Set heater temp to Hi on both sides, and you should get pretty much all of it out in one hit :y
polilara
  • Online Online
  • Finland
« Reply #2 on: 17 March 2020, 08:33:24 »
OK, thanks, I'll do it twice. Anybody know where to find those NORMA clamps for heater metal pipes to make that part flush easier?
« Reply #3 on: 17 March 2020, 08:41:06 »
 :-\ :-\ I remember only draining about half the system from the drain tap  :-\ :-\
polilara
  • Online Online
  • Finland
« Reply #4 on: 17 March 2020, 08:45:13 »
Hi Andy B, yes I'll do it twice so I am in 75% level at least. Those NORMA clamps would be nice to find for effective heater matrix flush.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 17 March 2020, 10:54:46 »
they're no better for cooling systems than a much cheaper and compact ordinary worm-drive hose clamp. Jubilee were the first, and are readily available. A 25-35mm hose clamp tightened to 5.1Nm(a tweak with a screwdriver) is rated to 102psi, which is much more than the14psi in a cooling system. Most of the 'problems' with Jubilee clips are due to operator error: too tight, or using too big a clamp.
« Reply #6 on: 17 March 2020, 20:51:26 »
I reckon about half comes out when draining through the radiator tap.
Jubilees are never recommended. Ever. They cause failures, and are themselves unreliable. Thats why nobody uses them.
« Reply #7 on: 17 March 2020, 21:48:29 »
I've never had a problem. I fitted them to the thermostat on my Smart as it was near impossible to re-fit the original spring clips ..... never leaked or broke anything. But as Nick suggests, they were the correct size & not over tightened. (and actual Jubilee clips .. not cheap versions)
... apart from me  ;)
« Reply #8 on: 18 March 2020, 03:33:31 »
Pressurise the bottle and you'll empty it all ::)
A bit of imagination goes a long way...
« Reply #9 on: 18 March 2020, 19:28:41 »
Yeah, but you're nearly as old as that Yorkshire Scouser, and we know old'uns can't learn new tricks :P
« Reply #10 on: 18 March 2020, 19:46:51 »
I have a wide range of sizes of stainless Jubilee clips that were 'requisitioned' from a previous employment  ::) and use an appropriate sized Jubilee  :-*
« Reply #11 on: 18 March 2020, 20:01:38 »
Thieving bastid ;D.  Is this why I can't buy Beanz anywhere?  I had to buy Branston crap at the weekend.  Though TBH, I suspect they will get donated to the local food bank, because they're bloody 'orrible.
« Reply #12 on: 18 March 2020, 21:02:55 »
Don't forget to weld the lid back on first...  ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #13 on: 18 March 2020, 21:34:27 »
IIRC Uncle Stemo invested all his ill gotten gains into Beanz before Brexit last march
he may still have half a shed full  :-\
« Reply #14 on: 18 March 2020, 21:46:52 »
Apparently we were really behind on orders before all this Covid 19 started.
The factory is running all week end every other week end for the next few months .... I worked last Fri Sat & Sun night  ... it's been a while since I last did nights & hope it'll be a while till the next  :o
