Author Topic: Elite door mirrors with memory  (Read 4857 times)
mantamania
  • Chatham, Kent
    • 2.6 Elite
« on: 17 March 2020, 15:58:28 »
Hi all, I have a 2002 elite of which a bit and run driver obliterated the drivers side mirror. All that is left is the metal frame and motor housing. I have one from my scrapped CD model and was wondering if I swapped the loom inside the mirror with the 9-pin loom from the elite one, would the memory work. Has anyone tried this.
  • Online Online
Re: Elite door mirrors with memory
« Reply #1 on: 17 March 2020, 18:05:58 »
I never had need to try buy can't see any reason why it wouldn't work
« Reply #2 on: 17 March 2020, 18:36:11 »
Fit the other one and call it done.
Unless you're bored of course ;)
  • Online Online
« Reply #3 on: 17 March 2020, 18:42:25 »
Isn't the Elite with memory mirrors & seat different from lesser models?  :-\
« Reply #4 on: 17 March 2020, 18:55:07 »
Plug is the same, along with most of the wiring. Memory is only two or three extra plugs ;)
If original Elite loom is still attached to the mirror arm and serviceable, then fine, but if not, swapping all the casing etc over is a bit of a ball ache compared to three screws to swap the assemblies...
  • Online Online
« Reply #5 on: 17 March 2020, 19:51:03 »
I swapped the loom over on the R Class mirror I bought as a replacement because the 'new one' had a standard mirror as mine originally had a dimming mirror (which I believe are silly money)
« Reply #6 on: 17 March 2020, 20:46:17 »
The actual mech is different between Elite and non memory models.  If you want to retain memory, you need to use an Elite mechanism and the Elite mirror wiring.
« Reply #7 on: 17 March 2020, 20:47:41 »
If it's salvageable  ;)
Also bear in mind that some mirrors sold by those in Euro land may have folding as well, and aren't compatible  ;)
« Last Edit: 17 March 2020, 20:49:12 by Doctor Gollum »
  • Online Online
« Reply #8 on: 17 March 2020, 21:54:22 »
I knew I was right  :y :y
« Reply #9 on: 18 March 2020, 03:30:46 »
The mech being the motor assembly and loom, not the arm itself  ;)
