Author Topic: Aircon - going to take a risk today  (Read 8095 times)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: Aircon - going to take a risk today
« Reply #15 on: 18 March 2020, 21:14:49 »
A vac check is not sufficient as a test .. it works in totatally the "wrong" direction so can only detect major problems .. it cannot detect a small leak at a joint as it sucks the joint tight ... whereas normal pressure forces it apart ....... applying suction (Vac) to a system that runs at around 14bar is useless... which is why a PRESSURE check with dry nitrogen is the only thing that works..... not rocket science but appears to be beyond the numpties who try to sell it.. and often succeed .. :(
They did the nitrogen test first
