Author Topic: builders next door  (Read 1668 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
builders next door
« on: 20 March 2020, 15:31:57 »
the old lady that lived next door to me was admitted to hospital & after about two months she died. ( age 93 ). the bungalow has been sold & builders are in. now being in that game myself i do know when living next door you can have to put up with noise, but i couldn,t believe this . a wagon turned up with loft insulation , only 8 rolls on a pallet with polythene to protect from damp.. the wagon was equipped with its own forklift but the driver actually dumped the pallet right in the gateway which is the way into both properties. it ended up being there for three days. the only way into both bungalows was to use my driveway gates,
Re: builders next door
« Reply #1 on: 20 March 2020, 15:36:10 »
That's hairy-arsed builders for you. :-X
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #2 on: 20 March 2020, 15:53:28 »
No
that's delivery drivers for you  ;D
though the builders should have moved it ,along with TRYING not to inconvenience other residents
had you still got the omega, you could have rammed it all out the way
advise you don't try it with your French car though  ;D
« Reply #3 on: 20 March 2020, 16:08:47 »
Cut through the protective polythene on the bit that's on your side......and pray for rain.
« Reply #4 on: 20 March 2020, 18:32:04 »
No
Hairy-arsed builders are always blaming hairy-arsed delivery drivers :)
