Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 ... 30   Go Down
Author Topic: Anyone know about Astras?  (Read 114991 times)
Re: Anyone know about Astras?
« Reply #120 on: 10 April 2020, 14:05:11 »
Just ordered the top end gasket set. £60 delivered
£25 on 4 rocker cover injector seals as I broke one on removal
As it stands, this beast will have been purchased, trailered to me, and fully repaired all within three figures :)
Including dpf?
As I keep saying Steve, an angle grinder disc and couple of lines of weld shouldn’t up the cost too much  ;D
« Reply #121 on: 10 April 2020, 14:34:23 »
I'm not knocking that, James, according to Opti it's a planet killer anyway. Might as well hasten the end.  ;D
« Reply #122 on: 10 April 2020, 21:05:02 »
Not much progress today, spent most of it drinking beer, went for a dog walk and lazing around.
But, I torqued up the con-rod for the piston I fitted, and fitted the cover protection plate thingymabob that covers the bottom end, as well as the strainer:
I then had a look at the upper sump:
And cleaned it up a bit
Can't get any dealer parts at the moment, so I made do with some loctite grey sealant I had, which I'm sure will do the job (Grey is correct for sumps)
And after cleaning it up, placed a bead around the sump:
And refitted it to the car.
It actually took ages - it was really fiddly to get back on, it connects to the gearbox, and also a bracket on the OS driveshaft, which really got in the way when trying to maneuver it back on.
The lower sump is also back on, so, sumps, done :y
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #123 on: 10 April 2020, 21:14:15 »
Sure that’s a sump baffle to stop the oil slushing about when you’re hooning  around👍
Laying a rubber road.
« Reply #124 on: 10 April 2020, 21:17:01 »
It's best put the bead around the bolt holes, not over them  :y :y
« Reply #125 on: 10 April 2020, 21:18:50 »
Good point well made, actually. :y
It aint coming back off now, though!!  :D
« Reply #126 on: 10 April 2020, 21:20:38 »
 ;D ;D ;D ;D
« Reply #127 on: 10 April 2020, 21:22:34 »
I had a bit of a wobble, earlier, thinking "Am I pissing in the wind" / wasting my time, trying to get this clapped lump running.
But looking at it logically, I don't see why it shouldn't work  :-\ - It was running on three before, and, it's pretty obvious why no4 wasn't firing....
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #128 on: 10 April 2020, 21:27:26 »
always scary when you first turn the key after a rebuild and it bangs and clatters  :o
then the lifters fill with 710 and all is good with the world  :)
i'm sure it will be a great run-a-round when done  :)
i much prefer the astra estate to the hatch  :y
Raeturbo
  • South Wales
« Reply #129 on: 10 April 2020, 21:34:21 »
Me too  I have a 1600  16v Astra G lpg which I’ve butchered and drilled and fitted different injectors to  the manifold. The original kaltec system was crap on them, still using the same ecu though and abused the little darling for five  years so far it’s indestructible👀
« Reply #130 on: 10 April 2020, 21:40:33 »
ESP in diesel form  :y
« Reply #131 on: 10 April 2020, 21:59:44 »
I drove a 1.6 petrol Astra J last year, a 2011 model, with only 30k on the clock, a very reliable and good car, but it lacked any poke at all, and only averages 35mpg!
Whereas, in comparison, the work cars I used to drive a few years ago, were 1.3CDTi - and much better than the 1.6 petrol.
« Last Edit: 10 April 2020, 22:01:15 by JamesV6CDX »
« Reply #132 on: 10 April 2020, 22:07:19 »
That 1.6 really needs a turbo...
« Reply #133 on: 10 April 2020, 22:10:44 »
My 2.0 165bhp gets along the road nicely, and 40+mpg around town.
« Reply #134 on: 10 April 2020, 22:21:29 »
If ever I'm in your neck of the woods, we'll have to go for a couple of pints, and I'll have a go in that :y
In reverse order, obviously! :D
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 ... 30   Go Up
Page created in 0.025 seconds with 20 queries.
