Pages: 1 ... 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 ... 30   Go Down
Author Topic: Anyone know about Astras?  (Read 115277 times)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Anyone know about Astras?
« Reply #150 on: 11 April 2020, 22:36:41 »
remove the pipe and ram a bar in to the box and smash it out with no damage to the casing. As far as the mot went, it was still there untampered with and sailed through each time.  :y
Things may have been tightened up since then though as that procedure became common knowledge.
It's still a "visual inspection".
So, they can't tap it to see if it's hollow.
If one were to therefore hypothetically, weld the box back up, and fit a generic round heat shield around the DPF...............
Personally, Id rather cut it open than run a bar through it. That shit gets in every nook and cranny, and I'd want it all fully removed :y
On the pick up, the pipe came off and you have access to both ends. I even sanded it all out inside so it was spotless.  :y
« Reply #151 on: 11 April 2020, 22:45:04 »
« Reply #152 on: 11 April 2020, 22:47:53 »
Wouldn't it trigger a code so the EML or a message came up?  :-\
And if you put it in for MOT (hypothetically..), wouldn't they be able to tell via the emissions test?  :-\
'Scuse my ignorance but I've never owned a car with a DPF....  :)
« Reply #153 on: 11 April 2020, 22:55:46 »
Emissions is just a smoke test, so as long as the engine is in good fettle, it's no issue.
It MAY trigger a code, but you can, hypothetically, fit resistors to the sensors in the rear or the DPF to prevent that  :-X
Jokes aside, if I get it running really well, I am likely to just fit a new DPF, with my driving style and route types  it's unlikely to block.
But, for the purposes of seeing how this repair goes, I'm not shelling out until I'm sure, and I don't think anyone would blame me for that :y
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #154 on: 12 April 2020, 00:14:10 »
Make sure you don’t breathe any of that shit in👍
Laying a rubber road.
« Reply #155 on: 12 April 2020, 01:32:22 »
I had the goggles and mask on :y
« Reply #156 on: 12 April 2020, 06:52:35 »
If he did, how would he go about doing a regen?  Vindaloo?  :-\
« Reply #157 on: 15 April 2020, 02:15:53 »
Might not be pretty, but it's gas tight, and very free flowing..............   a couple of generic round heat shields, and the "DPF" is as good as new :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #158 on: 15 April 2020, 12:21:55 »
excellent  :)
just waiting for gaskets then James ?
« Reply #159 on: 15 April 2020, 12:58:37 »
Yep, and a couple of days off work!
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #160 on: 15 April 2020, 13:11:54 »
I assume you know that the shit you removed has a decent scrap value
« Reply #161 on: 17 April 2020, 01:55:40 »
Even when highly contaminated with diesel and oil and god knows what? I just chucked it all away :y
« Reply #162 on: 17 April 2020, 08:51:57 »
At the very least you should have taken it to the tip :-X
« Reply #163 on: 17 April 2020, 10:13:14 »
At the very least you should have taken it to the nearest fly tip :-X
The Recycling Centres are all closed round here and surprise surprise there was a report on the local news last night about the increase in fly tipping.  ::)
« Reply #164 on: 17 April 2020, 10:15:51 »
Fair point, but the principle stands.
Pages: 1 ... 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 ... 30   Go Up
