Pages: 1 ... 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 ... 30   Go Down
Author Topic: Anyone know about Astras?  (Read 115047 times)
Re: Anyone know about Astras?
« Reply #255 on: 01 May 2020, 14:46:12 »
Found The home for the missing connector at the top. Only mystery is the plug on the turbo :y
« Reply #256 on: 01 May 2020, 14:46:47 »
Also just broke my pissing iPhone screen crawling under there, forgot it was in my pocket  :'(
Bugger!!!  :'( :'(
The irony is it cost more to buy than this car  ;D
« Reply #257 on: 01 May 2020, 14:52:35 »
Bugger!!!  :'( :'(
The thought had crossed my mind but didn't want to rub it in  ;) ;)
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #258 on: 01 May 2020, 14:54:47 »
There's another one to add into the 'disasters during lockdown' thread  :'(
But seriously, sorry to hear that James, especially as you were getting on so well.
Omega 2.5 V6 Facelift Estate.
« Reply #259 on: 01 May 2020, 15:00:24 »
What is the cable that can be seen hanging below the turbo?
« Reply #260 on: 01 May 2020, 15:04:27 »
I cant see an 1.7 CDTi turbo vac actuators with a sensor
« Reply #261 on: 01 May 2020, 15:34:16 »
It’s a sensor that goes in the front of the exhaust :y
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #262 on: 01 May 2020, 15:41:04 »
I stand my reply, post #196.  ;D
« Reply #263 on: 01 May 2020, 16:25:53 »
Exhaust gas temperature sensor, I would be putting it back together and running it, if its an issue it will throw a code.
  • Auckland
    • Mazda MPV
« Reply #264 on: 01 May 2020, 20:35:30 »
There is jack all of value in a DPF, its just ceramic composites, its CATs and SCRs that have valuable metals in them.
And you shouldn't need to do anything to keep the ECU light off, its only a temperature and pressure sensor which can be left connected
I still say you need to get those injectors sorted, your piston failure was not foreign body caused, its overheated
I have been trying to get my head round that level of overheating. I assume that the injector must have been pissing fuel in all the time  :-\
I also assume that it would be obvious to any normal driver that something was seriously amiss .
Is there any chance that something wiring or ECU related could cause this issue? I have this notion that some piezo injectors have to be turned off after they have been turned on. If the wiring to one of those piezo injectors becomes faulty then they can get stuck open. (Not saying that Astras have this type of injector BTW)
« Reply #265 on: 01 May 2020, 20:49:34 »
Today’s progress in a video:
https://youtu.be/8-BZsOk7-Ec
Requires sound
« Last Edit: 01 May 2020, 20:53:58 by JamesV6CDX »
« Reply #266 on: 01 May 2020, 21:02:44 »
Requires sound
It's making cement mixer sounds so it must be fixed. :D
« Reply #267 on: 01 May 2020, 21:09:34 »
Job jobbed 8)
Wipe its arse and kick it out the door :y
« Reply #268 on: 01 May 2020, 21:22:25 »
Need to road test first :D
Here was the actual very first startup - again needs sound!
https://youtu.be/jZ9bU4vHK38
« Reply #269 on: 01 May 2020, 21:25:08 »
Amazing what a bit of fuel can do :D
Pages: 1 ... 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 ... 30   Go Up
Page created in 0.029 seconds with 20 queries.
