Pages: 1 ... 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30   Go Down
Author Topic: Anyone know about Astras?  (Read 115056 times)
Re: Anyone know about Astras?
« Reply #330 on: 06 May 2020, 11:45:13 »
Been a while since I used one, but clicking upgrade used to physically destory the chip, game over time.
Ive no experience on them on later cars
I think that’s if you click “internet update”. This was a manual firmware upgrade :y
Car is back with the garage. Since they’ve coded the injectors it’s undrivable. It’s running on 4 but massively over fuelling and ticking and chucking out smoke
Let’s hope today they can do those adjustments otherwise I don’t know where to turn. I can’t drive it far like that, too much risk of damage with that much fuel going in :(
Wish I’d left it now. Other than being noisy it was running ok before I took it in!
« Reply #331 on: 06 May 2020, 12:21:47 »
So what exactly was the fault codes?
Code and suffix (so 4 digits plus 2)
Astra J is full CAN hence there may be hardware difference in the diagnostics comms
« Reply #332 on: 06 May 2020, 13:29:10 »
"P06B-41 Fuel Injection Small Quantity Not Learned - Not Programmed".
« Reply #333 on: 06 May 2020, 15:25:01 »
That's not a valid code as its 3 digits and 2 digits  :y
P062B-41?
« Reply #334 on: 06 May 2020, 15:38:56 »
P062B-41?
Sorry mark just checked my photo of the “tool” output - that’s the one :y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #336 on: 06 May 2020, 16:38:26 »
Quick search;
https://workshop-manuals.com/vauxhall/astra-j/engine/engine_control_and_fuel_system_1.7l_diesel_(lpl_or_lpv)/diagnostic_information_and_procedures/miscellaneous/dtc_p0601_p0606_p060a_p060e_p0610_p061a_p062a_p062b_or_p062f_lpl_or_lpv/
If code persists, replace K20 engine control module.
Is this the problem which caused the initial faiulure??   :-\ :-[
The code is there because the injectors were coded but they couldn’t compete the small learning procedure because of a fuel temperature error.
We will see how they get on today :y
« Reply #337 on: 06 May 2020, 16:58:49 »
Hmmm, usually the idle learn process requires a minimum stable rail pressure, engine temp (typically at or above 80 degrees C) and fuel temp (30 degrees C rings a bell).
The latter can take a while to achieve, usually needs a hot engine plus some heat soak, if its throwing an issue with this the first thing a competent mech should do is look at the fuel temp live value to see if its not quite upto temperature OR if its a ridiculous reading which hints a fault.
When the learn happens, the ECU will raise the rail pressure to max (a few thousand Bar) and then trim the injection pulses to get optimum idle. The learnt values are also a useful indication of injector condition as they should be fairly similar (its worth asking for them)
« Reply #338 on: 06 May 2020, 17:21:33 »
 the ECU will raise the rail pressure to max (a few thousand Bar) and  .....
How much?  :o :o :o :o :o :o
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #339 on: 06 May 2020, 17:31:29 »
                     Around 26106 PSI.
Laying a rubber road.
« Reply #340 on: 06 May 2020, 17:33:53 »
From stuff I've read, on this engine it's 1800bar / 26,106PSI
Anyhow. I also had my suspicions that (due to the fact I'd left it there the night before) they had done it with a cold engine.
So, this time, I took it for a spin and delivered it fully up to temperature.
The learning process worked this time. Not sure if this was a result of me cleaning the temperature sensor plug, or being up to temperature, but either way, it worked  :y
Car seems to have ceased over fuelling now and is not chucking out smoke.
So, we have 4 injectors which we know are correctly coded to the ECU :y
On the way back from the garage, though, I noticed the car was noisier and more rattly than ever. I think I've identified what the cause of that is, I'm just off out to investigate it and I'll post up for sure if it's what I think it is. Clue - it's not a diesel injector  ::)  :-[
« Reply #341 on: 06 May 2020, 17:42:40 »
No.....just a diesel.  ;D
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #342 on: 06 May 2020, 18:36:01 »
Wow this is a long thread about an Astra , think I would have moved it on & bought something else.
« Reply #343 on: 06 May 2020, 18:43:28 »
Nobody is forced to read it :y
I don’t like giving up. And I didn’t but the car for what it is / isn’t - I just fancied a challenge. From when it arrived, I think loads of progress has been made, and for me that makes me happy.
I find it interesting, anyway :y
« Reply #344 on: 06 May 2020, 19:04:51 »
Not as long as think of a word that's nothing like the last word and repeat 2 million times  ;D
Pages: 1 ... 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30   Go Up
Page created in 0.023 seconds with 20 queries.
