Author Topic: Urgent help needed - aux belt tentioner bolt heads rounded  (Read 6388 times)
dave.h
  • Cumbria
    • 2.2 CDX auto/C220 auto
Hello all
I started doing the timing belt on my V6 this morning and when it came to removing the aux belt tensioner, I discovered that some halfwit has rounded the bottom torx bolt.
I have tried hitting the correct sized socket on but I can't get any purchase to both hold the socket in place and get a hit with the hammer.
Does anyone have any ideas how I can get this out?
Are there extractors?
Success is not final, failure is not fatal, it is the courage to go on that counts
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Urgent help needed - aux belt tentioner bolt heads rounded
« Reply #1 on: 05 April 2020, 14:20:29 »
smaller 6 sided socket hammered on has worked for me in the past  :y
« Reply #2 on: 05 April 2020, 14:26:31 »
Or a suitable ring spanner :y
dave.h
  • Cumbria
« Reply #3 on: 05 April 2020, 16:11:32 »
I can't get it moving with either a smaller hex socket or ring spanner.
I can't upload a picture but it's been properly butchered by some fool.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 05 April 2020, 16:21:00 »
What size torx is it meant to be ?
that set may not be small enough  :-\
could try some heat (in case someone put masses of threadlock on)  ::)
then any socket you can get hammered on tight
good luck  ;)
dave.h
  • Cumbria
« Reply #6 on: 05 April 2020, 16:25:50 »
good luck  ;)
Its a No 14 torx socket that fits the top bolt, I will try and get a set of extractors as mine don't go small enough.
Bloody nuisance, could have had the job done and dusted by now.
« Reply #7 on: 05 April 2020, 16:30:30 »
Ring spanner. Also you're pulling it UP from the front of the engine so will be lifting against the weight of the engine, so no worries on leverage.
Can't remember if you need to shift the alternator to remove the bolt... May help access shifting it :y
dave.h
  • Cumbria
« Reply #8 on: 05 April 2020, 16:38:25 »
None of my ring spanners shifted it but I think getting t he alternator out of the way may help. What really gets in the wat are the 2 steel pipes running along the engine.
« Reply #9 on: 05 April 2020, 17:02:27 »
https://youtu.be/ja7Ax45DGT8
Imagination and Weetabix... Get it done ;)
Steveh
  • Debyshire UK
    • Omega 2L 16V
« Reply #10 on: 05 April 2020, 17:08:55 »
Do you have a welder? you could tack a nut on or a bit of bar and the heat will also help if free.
« Reply #11 on: 05 April 2020, 17:28:37 »
Irwin sockets. Google them. They’ll do it in an instant :y
dave.h
  • Cumbria
« Reply #13 on: 05 April 2020, 17:31:54 »
I think the bolt head might be made from Weetabix...…..the idiot that rounded it definitely had his Weetabix as the bloody thing is well stuck! :-)
Ordered the Irwins as well as the additional set so hopefully they will arrive at some point in the week and I can crack on!
« Reply #14 on: 05 April 2020, 17:36:34 »
Alternator out, smack an E12 onto it and a breaker bar.
Or hacksaw it off and unwind the rest once the tensioner is  off ;)
