Pages: 1 [2] 3  All   Go Down
Author Topic: Vectra estate reversing sensors - I need power source.  (Read 10566 times)
Re: Vectra estate reversing sensors - I need power source.
« Reply #15 on: 06 April 2020, 18:13:18 »
1.If you insist on using F28, make sure it doesn't feed anything else.
2. Irrelevant, although you want the relay in the same postcode as 1 and 3.
3. Identify the feed to the reversing light bulbs and use that. Be advised it may not be happy.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #16 on: 06 April 2020, 19:49:39 »
The only vacant relay bases are in the under bonnet fuse box. I presume the reversing light switch is under the bonnet too. Is the best solution to run a cable from bonnet to back of car?
« Reply #17 on: 06 April 2020, 19:59:16 »
Didn't you read my post?
It is possible that the rear lights are all operated by a single ecu*, which illuminates each light on demand, in which case you really don't want to hack into it.
Factory parking sensors were basically a £1,000 option and only fitted to both ends.
Trying to use any prewiring to fit aftermarket sensors won't end well.
* I never got that involved with my Vectras, but I know that it will repurpose any rear light in the event of brake light failure so a single lighting control ecu wouldn't be a surprise.
I have two suggestions, but you might not like them...
terry paget
    • 3 Astras 2 Vectra
« Reply #18 on: 06 April 2020, 20:59:50 »
I did say I do not understand Canbuss wiring systems. should like to hear your suggestions I wonder now whether I should wire the reversing sensors independent of the reverse gear, n a simple switch.
« Reply #19 on: 06 April 2020, 21:05:37 »
Wire them directly to an ignition live and call it done.
They should only sound if something is anywhere near whilst you are in the car, so as effective as factory ones.
The other suggestion is not to bother.
« Reply #20 on: 06 April 2020, 22:11:39 »
I would use a switch. It's a bit annoying when someone walks past the rear of your car or the driver behind gets close in a queue.
« Reply #21 on: 06 April 2020, 22:39:03 »
I only use mine cos they're there .... I'd not go to the effort of fitting them.  :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #22 on: 07 April 2020, 11:24:01 »
There is no point fitting reversing sensors that don't automatically switch on when you select reverse. You'll never use them!
If I couldn't wire them using resources near the back panel, I wouldn't fit them at all. When you buy them, pay the extra couple of quid for sensors that match the bumper colour.
I doubt that any of the aftermarket sensor kits draw enough current to need a relay; the ones I fitted to my estate were powered directly off the towbar wiring, although I did fit a fuse. I don't know enough to say if that method would work on canbus. If it were mine, I would power the sensors off a separate ignition feed(tow bar socket or charging accessory if there is one) and before doing anything irrecoverable, would experiment with the reverse light wiring to switch everything on. If that caused problems with the canbus, then I wouldn't bother with the install. I was surprised how useful parking sensors are - I paid about £12 for the kit - but it's not worth a lot of grief fitting them
terry paget
    • 3 Astras 2 Vectra
« Reply #23 on: 07 April 2020, 15:52:33 »
Thanks, Nick. I am making hard work of this installation, to my dismay. There are 2 sockets in this car boot, see above pic, which may include a reversing light on power pin. Any idea which it might be? Also I am struggling to remove the rear seat cushion. Haynes says 'pull the front of the cushion upwards to disengage the front mountings'. I have done that, to little effect.
« Reply #24 on: 07 April 2020, 18:45:05 »
Re rear seat try harder, it just hoiks out same as the Omega :y
« Reply #25 on: 07 April 2020, 18:55:52 »
https://www.ebay.co.uk/itm/Vauxhall-signum-vectra-Park-Pilot-Sensors-Module-Switch-loom/143573916292?hash=item216dac1a84:g:zvMAAOSw5Xxeiz7f
Not sure what else is required, possibly front bumper sensors/loom, but this should be plug and play :y
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #26 on: 07 April 2020, 19:35:47 »
Has it got a tow bar fitted Terry? if not, fit one. If yes, there's your rear parking sensor. Job done. ;)
« Reply #27 on: 08 April 2020, 10:19:25 »
Vectra owners forum suggests that the factory Bosch system is pretty much plug and play. You're biggest issue will be collecting the parts, and it won't cost a tenner.
The ebay link I posted is everything you need for the genuine rear system, and I believe that it only requires the front bumper loom and sensors to complete. Also being a used system, it should be easy to identify the connections to existing wiring.  :y
Or you can spend the rest of the month getting frustrated...  ::)
terry paget
    • 3 Astras 2 Vectra
« Reply #28 on: 08 April 2020, 19:39:45 »
I have a Vectra 08 saloon DN08, on which I have successfully arranged that engaging reverse gear activates the reversing sensors.
There the power cable is black/white and the earthy cable is brown.
terry paget
    • 3 Astras 2 Vectra
« Reply #29 on: 08 April 2020, 19:57:58 »
On the Vectra estate the earthy cable again is brown, but the power cable is black, as are several other cables. Engaging reverse gear, ignition in position 2, the only black cable that has 12 volts on it is the thin black cable top right of the bottom group.
Accepting that I do not know what I am doing dabbling with canbuss wiring fitting reversing sensors, and having got away with it once, I am inclined to try it again.
Pages: 1 [2] 3  All   Go Up
