Idler Arm part question
Started by Andy A, 10 April 2020, 20:08:01
Andy A
Got it out. Refitting into my Idler arm should be fine. The bloke on Ebay has out another one up for sale if anyone needs a replacement Bush.
Thanks all for youe help.  :y :y
cam.in.head
if it was tight i was going to suggest cutting a groove in the surrounding arm to releive the tension but you have beaten me to it and already got it out.at least the proper omega arm will now have good quality oem bush and should last a fair while. this is how i did mine 5 years ago and all is still well as i expected
Andy A
Just got to find the time to take the old arm out. Weather looks good this week as well.
It's only two nuts, have you done it yet?
Migv6 le Frog Fan
Quote from: Andy A on 19 April 2020, 15:39:07
I bought the one he had left, so at some point need to go through the bush pressing out / in process. No great hurry as mine is in reasonable condition anyway.
Andy A
Quote from: Migv6 le Frog Fan on 19 May 2020, 21:30:54
Nice one.  :y
Haven't fitted mine yet, still working on my son's car in-between other things.
I'm wondering whether to replace just the centre rubber and inner sleeve into the old outer sleeve or just change the bush complete with outer and inner sleeve. Anyone with any thoughts on that?
Between the rubber part and the outer metal sleeve it is lubricated. Should I re-lubricate this if I chose to use old outer sleeve and what lube should I use?
