Pages: 1 [2] 3  All   Go Down
Author Topic: Big Ends  (Read 4254 times)
yorkshire ripper
  • leeds
Re: Big Ends
« Reply #15 on: 28 August 2008, 23:05:03 »
See that"s what seperates the fine ladys of oof from the usual women of a ""certain age"" who try dressing up in the daughters clothes thinking there 25 again.... ;D
A love of old smelly oily machines.... :y
very true, i was at pickering traction show a few week ago and it was great to see mucky women..oooo errr.. in overalls working on the engines..
lee
Jay w
  • Plymouth/Poole
  • omega gone
Re: Big Ends
« Reply #16 on: 28 August 2008, 23:37:16 »
i am, unfortunately, from an era that never understood the attraction of steam......
That said i still marvel at the engineering that went into locomotives, but they have never stirred my emotions, i will most likely be branded a heathen now  :-[
Re: Big Ends
« Reply #17 on: 28 August 2008, 23:41:26 »
I love steam trains too Lizzie.
I remember going to the local railway bridge and waiting for the Flying Scotsman to go past. It's like a living being. :y :-* :-*
I used to do that as a kid, lean over the bridge and get a face full of smoke and smells, of course up here we are still building propper trains. ;D ;D ;D
woodsy_mv6
  • West Sussex
Re: Big Ends
« Reply #18 on: 29 August 2008, 11:14:52 »
Cracking peices of machinary :y
I've got the Bluebell railway round the corner from me (just down the A22)
Haven't been there since I was a kid.
Might look a bit odd now if I turned up on my own looking at trains full of school groups
From the moment I picked up your book until I laid it down, I was convulsed with laughter. Some day I intend reading it.
Dusty
  • Shropshire
  • Erotic Romance Author
Re: Big Ends
« Reply #19 on: 29 August 2008, 12:28:47 »
There was something on the teevision recently about The Mallard.
I believe it still holds the speed record for a steam train.
126m.p.h. some time in the thirties .......might be best if I google that to be sure of my facts. :-* :-*
Martin_1962
Re: Big Ends
« Reply #20 on: 29 August 2008, 12:49:05 »
Still does - some argument over the Diesel record*, electric and gas turbine still French.
* BR, Spain and Russia all claim it and noone in the UK has considered the simple task of having another go to get it back for certain.
HST                  148.5 confirmed
HD Talgo     mid 150s rumoured
Russian DEMU mid 160s rumoured
Since the most powerful and aerodynamic is the British one, just  a matter of either a weak field or up gearing a pair of power cars.
HST is about 30% more powerful than the Talgo
FRE07962128
Re: Big Ends
« Reply #21 on: 29 August 2008, 13:18:23 »
Yes indeed; 126mph on 3rd July 1938 with 'A4' class LNER Pacific 4468 'Mallard' with a seven coach, 236.5 ton train (far from the heaviest!!) for five miles on Stoke Bank. :y :y
The engine driver Joseph Duddington (retired 1944) during high speed brake trials and no doubt as an attempt on the record as a publicity stunt, to acquire an advantage over their rivals the LMS, was done at significant risk, with 'Mallard' actually sustaining severe damage. :'(
It is argued that the A4 class was the only locomotives in the UK to be able to achieve 100mph in everyday running. ;)
« Last Edit: 29 August 2008, 13:19:59 by FRE07962128 »
Martin_1962
Re: Big Ends
« Reply #22 on: 29 August 2008, 14:42:51 »
100mph club
Castle
King
Merchant Navy
Duchess
Princess
A1
A3
A4
There will be more I think that Britannias and Duke of Gloucester are members too
Best member of the 90mph club is the 9F
FRE07962128
Re: Big Ends
« Reply #23 on: 30 August 2008, 17:00:51 »
100mph club
Castle
King
Merchant Navy
Duchess
Princess
A1
A3
A4
I knew my comment would cause a comment, but I did say "argued" Martin, as engineers, historians and enthusiasts alike have many different views over the ability of many fine engines, some of which you rightly list, over their ability to achieve and maintain certain levels of speed, let alone 100 mph, along with efficient output in "everyday use".
Many variable  factors, such as ability to raise and maintain steam pressure - boiler design - firebox grate area - superheater efficiency - steam pipe design efficency - blast pipe and chimney layout, etc, etc, along with bearing surface areas, valve gear design, piston / cylinder layout / travel, then wheel size and arrangement, with the overall weight consideration are, as you no doubt know, all contributing to the complicated and often controversial "package" of whether or not engines can achieve 'continual' maximum output efficiency on the main line.
Then you add the variable of the individual engine drivers and fireman along with the geography of their particular line routes, and it is not surprising many 'argue' over which engine and class was actually the most reliable, efficent, and fastest out of them all.  Personally I certainly believe, given the 'right' situation, the 'Kings' and 'Duchess's could always have equalled the 'A4's' in everyday running. :y  The 'Merchant Navy's' could only do so once rebuilt, but any form of "everyday" 100 mph performance was only achieved occasionally by drivers out to give them a final thrashing before withdrawal.  The 9F's on "everyday running" I doubt due to their 'freight engine' layout, and especially on 10 coupled 5' 3" wheels. :-/ :-/  After all they were not designed for speed but long term power output.
This argument will no doubt go on indefinately (especially as new facts are established such as with the 'ashpan draughting flaw' of 8P Standard Class 71000 'Duke of Gloucester' discovered a few years back during restoration) but we as knowledgable historians / engineers / enthusiasts must accept the fact that the 'A4' class does still hold the World steam railway engine speed record of 126 mph which the LMS, GWR and Southern (or later BR!!) failed to equal or exceed with their engines, and the A4's did run as true 100 mph locomotives in "everyday use". 8-) ;)
« Last Edit: 30 August 2008, 17:01:58 by FRE07962128 »
Dusty
  • Shropshire
Re: Big Ends
« Reply #24 on: 30 August 2008, 17:06:33 »
Well you certainly know your steam trains Lizzie. I always loved The Mallard for the way it was shaped at the front.
To help push it through the air at high speed presumably. :-* :-*
Re: Big Ends
« Reply #25 on: 30 August 2008, 17:13:48 »
You would think that but, in reality it was more a commercial thing as it did little if anything for the aerodynamics.
FRE07962128
Re: Big Ends
« Reply #26 on: 30 August 2008, 17:30:13 »
Indeed Mark, as this was the 1930's and a big national drive for speed in all things, and especially the railways ensued with big PR advantages gained for either the LMS, on the Western main line, or LNER on the Eastern main line, in achieving a "fastest" train acculade for scheduled services between London and Scotland to put in their publicity machine.  Streamlining looked so good as an image  for this time, but had little advantage apparently :y
« Last Edit: 30 August 2008, 17:31:16 by FRE07962128 »
Martin_1962
Re: Big Ends
« Reply #27 on: 30 August 2008, 18:25:56 »
Lots of aerodynamics - mainly internal!
Martin_1962
Re: Big Ends
« Reply #28 on: 30 August 2008, 18:30:18 »
9Fs at 90 actually it wasn't just a one off, Evening Star was used on express services to South Wales, at high speed, until told off :(
A 9F was officially clocked at 90 on ECML service
FRE07962128
Re: Big Ends
« Reply #29 on: 30 August 2008, 19:00:50 »
At 90 maybe, but as I stated not 100 mph in "everyday use" :y
Pages: 1 [2] 3  All   Go Up
Page created in 0.022 seconds with 20 queries.
